This DVD writer provides professional-quality DVD and CD performance for writing, rewriting and reading. It supports Running OPC (ROPC). In addition, the drive is equipped with buffer underrun technology to eliminate buffer underrun errors, so you can safely use your computer for other things while you're writing to DVD or CD, and using a web connection, you can update this drive's flash memory to the latest firmware revisions without opening the drive.
LiteOn IHAS120 20X DVD±RW (Dual ±R)/RAM SATA Drive (Internal, Bare, Black)
- Type - Half Height (HH) Internal Combination Drive
- Interface - SATA
- Support Double Layer DVD+/- R9 Recording Function
- Features - SMART-BURN + SMART-X functions
- Support both 8cm and 12cm disc of CD and DVD family
- SATA interface, Half-Height internal DVD+R / DVD+RW / DVD-R / DVD-RW / DVD+R9/ DVD-R9/ DVD-RAM/ DVD-ROM / CD-R/ CD-RW / CD-ROM combination drive
- SMART-BURN function Automatically adjusting writing strategy & walking OPC to provide the best burning quality
- SMART-X(*) function adjusts CD-DA / VCD / DVD data extraction to a fastest allowable speed according to both data request rate from host and disk quality
- Support Fixed Packet, Variable Packet, TAO, SAO, DAO, Random Access Write, Incremental, sequential recording, restricted overwrite, Layer Jump recording, Raw Mode Burning & Over-Burn
- DVD read compliant: DVD single/dual layer (PTP/OTP), DVD-R, DVD-R multi-borders, DVD-RAM DVD+R, DVD+R multi-sessions, DVD-RW, and DVD+RW
- CD read compliant: CD-DA, CD-ROM, CD-ROM/XA, Photo-CD, Multi-session, Karaoke-CD, Video-CD, CD-I FMV, CD Extra, CD Plus, CD-R, and CD-RW
- Conform to Orange Book: Part 2 CD-R Volume 1, Part 2 CD-R Volume 2 Multi Speed,
- Supported transfer mode: PIO mode 4, DMA mode 2 and Ultra DMA mode 5
DVD Family
Write
- DVD+R 20X maximum by CAV
- DVD-R 20X maximum by CAV
- DVD+R9 12 maximum by CAV
- DVD-R9 12 maximum by CAV DVD-RAM 12X maximum by PCAV
ReWrite
- DVD+RW 8X by CLV
- DVD-RW 6X by CLV
Read
- 16X maximum by CAV
- Rand. Access Time 160ms
CD Family
- Write CD-R 48X by CAV
- ReWrite CD-RW 24X maximum by Z-CLV in UltraSpeed disc
- Read 40X maximum by PCAV
- Rand. Access Time 140ms
- Buffer Size : 0.5 MB(MAX)
Spec
