Linx Tough Tab 8 with Barcode Scanner.
Designed to be used in a variety of extreme environments, the Linx Tough Tab
8 is the perfect tablet to withstand everything that your business can throw
at it. Powered by a Quad-Core Intel® processor and Windows® 8.1 Pro
operating system, the IP-67 rated tablet can withstand submersion in water,
dusty environments and can integrate seamlessly into your business to give
you complete control and visibility over every department.
Built-in Stylus.
A discreet built-in capacitive stylus provides precision navigation and is
designed to aid the function of any workforce.
Impact Protection.
Rigorously designed and drop tested to IEC-60068232 standards up to 1.2M,
the Tough Tab 8 is protected from accidental bumps with reinforced edge and
corner protection.
IP67 Certified.
For complete peace-of-mind, IP67 certification ensures that the device is
totally protected against dust and can withstand immersion into liquids up
to a depth of 1 metre.
Connectivity assured.
Always keep connected wherever your team is based with Bluetooth 4.0, a 3G
micro-SIM card slot and Wi-Fi 802.11 b/g/n connectivity. GPS tracking lets
your team use location-based apps for increased accuracy and security
wherever they are.
Integrated barcode scanner.
With built-in barcode scanning, look to the Linx Tough Tab 8 as the perfect
solution for your business. Work faster, more efficently and more
effectively.
Easy-hold hand strap.
The Linx Tough Tab 8 easy-hold hand strap has a fully removable back plate
that securely screws into the tablets main body. With 360-degree rotation,
users can position their tablet in either vertical or horizontal orientation
for ease of use.
