Linksys X3000 Advanced Wireless-N ADSL2+ Modem Router
Create a high speed wireless home network suitable for your DSL or cable broadband connection.
Ideal for
- Sharing Internet access, surfing the web, emailing and printing wirelessly
- Connecting multiple devices and to add USB storage to the network
- Connecting to a DSL connection or cable modem
Key features
- All-in-one device - functions as a wireless ADSL2+ modem router or a wireless router
- Wireless-N router with wireless transfer speeds up to 300 Mbps
- Reliable range with MIMO antenna technology
- Four Gigabit Ethernet ports for speeds 10x faster than Ethernet
Built-in DSL modem
Directly connects you to the internet wirelessly --no separate DSL modem required. The Linksys X3000 can also act as a wireless router by connecting the Ethernet WAN port to a cable modem.
Fast wireless speed
The Linksys X3000 connects your computers, wireless printers and other Wi-Fi devices at wireless transfer rates up to 300 Mbps.
Reliable wireless coverage
The MIMO antenna technology provides broad coverage so you can enjoy your wireless network from anywhere in your home.
Benefits of Gigabit
Use the four Gigabit Ethernet ports for quick file sharing, 10x faster than standard Ethernet, between other Gigabit-enabled devices like computers, hard drives, and servers.
Built-in StorageLink port and UPnP media server
The StorageLink USB port lets you add storage devices to your network to share files wirelessly throughout your home. The built-in UPnP AV media server enables media streaming to your Xbox 360, PS3, or other UPnP compatible devices.
Advanced security
Advanced security features such as WPA2 wireless encryption and the integrated firewall help you keep your network protected.
Quick to install
Cisco Connect helps you set up your wireless network in a few easy steps on a Windows or Mac computer.
Easy to manage
Cisco Connect works with Mac and Windows computers and helps you customize settings or quickly add new devices to your network. Cisco Connect enables you to:
- Create a separate, password protected network for guests
- Limit access time and access to certain websites with parental controls
- Access advanced network settings easily
- Measure your connection speed with the Broadband Speed Meter
- Perform regular automated update checks for firmware and software with the option to install
