            Upgrade the data transfer speeds of your local wired network to information superhighways with the Linksys LGS116 16-Port Desktop Gigabit Switch.
This Linksys LGS116 16-Port Switch allows you to accelerate your performance and productivity when you send large files to network servers, drives, and printers at Gigabit speed. Furthermore, the Linksys LGS116 switch is simple to set up offering a quick and easy solution to extend your office network.
Gigabit Performance
This Linksys LGS116 16-Port Desktop Gigabit Switch offers Gigabit speeds to minimise transfer times and greatly enhance the ability to stream high bandwidth files to connected devices without interference.
Quality of Service (QoS) traffic prioritisation
QoS traffic prioritisation provides the ability to give precedence to particular devices or activities to ensure mission critical data throughput is maintained regardless of network congestion. Auto-sensing ports automatically optimise speed for each connected device.
Sixteen (16) 10/100/1000 Gigabit Ethernet ports.
Quality of Service (QoS) traffic prioritisation.
Easy plug and play connection for simple set-up.
Fanless design ensures quiet operation.
Wall mountable for convenient deployment.
Power saving features: Cable connected detection and sleep mode.
Supporting standards: IEEE 802.3, 802.3u, 802.3x, 802.3ab, 802.3az.
Strong robust metal enclosure design.
Standard warranty: limited lifetime
