The Linksys E1700 Wireless Router for cable Broadband is the latest member of the Linksys E-series family and offers the an increase in wireless range thanks to it's Wireless 802.11 technology and additional antennas. With Wireless-N speeds up to 300Mbps the Linksys E1700 is able to stream on all your wireless content to devices such as laptops, iPads, internet-enabled TVs, Blu-ray players and game consoles, over large distances, with ease. Additionally, the Linksys E1700 features a four built-in Gigabit Ethernet ports to supply high-speed connections to your wired devices.
Fast Wireless Speed: The Linksys E1700 offers fast speed to connect your computers, wireless printers and other Wi-Fi devices at transfer rates up to 300 Mbps speed.
Reliable Wireless Coverage: Built with leading 802.11n wireless technology, the Linksys E1700 offers reliable range to create a powerful wireless network. MIMO antenna technology provides broad coverage so you can enjoy your wireless network from anywhere in your home.
Advanced Security: Keep Wi-Fi freeloaders and Internet threats at bay, The Linksys E1700 offersWPA/WPA2 encryption and SPI firewall to help keep your network protected.
Quick Install: Cisco Connect software helps you set up your home wireless network in three easy steps.
Easy to Manage: Cisco Connect software helps you customise your settings, and quickly add multiple devices to your network:
Create a separate, password protected network for guests
Limit access time and websites with Parental Controls
Access advanced network settings easily
