21:9 Curved UltraWide QHD (3440 1440) display offers wrap-around field of view on a wide screen real estate. With IPS display, visual comfort is guaranteed while ensuring vivid and accurate color expression.
Thunderbolt 2 compatibility with Mac devices
With the Thunderbolt 2 port for Mac devices, you can take advantage of data transmission that is 4 times faster than the USB 3.0, and also can expand computing capability more easily via a simple daisy-chain con?guration without the need for an extra connector.
The beauty of ArcLine
Inspired by the beauty and power of nature, the ArcLine completes the design with a refined aesthetic flair.
Flawless color expression
You are guaranteed an immersive artwork through a sRGB over 99% color space.Color calibration tests are conducted on the production line to ensure color accuracy.
Amazing tech design
The amazingly designed ergonomic stand can be installed quickly and easily without the need for tools, and its height and tilt are adjustable for your comfort.
USB 3.0 quick charge
Charge the battery of a connected device quickly using the USB 3.0 port on the product.
Game Mode
Game Mode, consisting of FPS, RTS, and Custom modes, provides a customized gaming experience that varies with genres.
LG 34UC98 - LED monitor - curved - 34"
LED-backlit LCD monitor - 34"
Energy Class
Class B
Energy Consumption per Year
79 kWh
Power Consumption (On mode)
54 W
Curved Screen
Adaptive-Sync Technology
AMD FreeSync
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
21:9
Native Resolution
QHD 3440 x 1440
Pixel Pitch
0.2325 mm
Brightness
300 cd/m²
Contrast Ratio
1000:1
Response Time
5 ms (grey-to-grey), 14 ms (On/Off)
Colour Support
1.074 billion colours (10-bit)
Colour Gamut
99% Adobe RGB (CIE 1931)
Input Connectors
2xThunderbolt, 2xHDMI, DisplayPort
Display Position Adjustments
Height, tilt
Voltage
AC 120/230 V
81.76 cm x 23.04 cm x 45.14 cm
7.8 kg
FCC Class B certified, UL, TUV, BSMI, cUL, CCC, DDC/CI, ERP, EPA 6.0, EDID compatible
Display Type
Energy Class
Class B
79 kWh
Diagonal Size
34"
Curved Screen
AMD FreeSync
Built-in Devices
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
21:9
Native Resolution
QHD 3440 x 1440
Pixel Pitch
0.2325 mm
Brightness
300 cd/m²
Contrast Ratio
1000:1
Colour Support
Colour Gamut
Response Time
Vertical Refresh Rate
56 - 61 Hz
Horizontal Refresh Rate
30 - 90 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
LED backlight
HDCP, Picture Mode, game mode, On-screen Digital Controls, FPS Mode, Flicker Safe, Reader Mode, SIX Axis Control, PBP, MaxxAudio, Smart Energy Saving technology, Color Calibrated, Dual Controller, Black Stabilizer, DAS Mode (Dynamic Action Sync), Response Time Control, split screen 2.0, My Display Preset, Auto Power Off, Color Weakness Mode, Mega DFC, USB 3.0 Quick Charge
81.76 cm x 23.04 cm x 45.14 cm - with stand
7.8 kg
Audio
Speakers - stereo
Output Power / Channel
7 Watt
2 x Thunderbolt , 2 x HDMI , DisplayPort , 2 x USB 3.0 downstream , USB 3.0 upstream
Mechanical
Height, tilt
Tilt Angle
-5/+15
Height Adjustment
110 mm
VESA Mounting Interface
100 x 100 mm
Key lock
Stand
Input Voltage
AC 120/230 V
54 W
Power Consumption (Typical)
70 Watt
Power Consumption Sleep
1.2 Watt
Microsoft Windows
Dimensions & Weight Details
With stand - width: 81.76 cm - depth: 23.04 cm - height: 45.14 cm - weight: 7.8 kg , Without stand - width: 81.76 cm - depth: 8.87 cm - height: 36.08 cm - weight: 6.2 kg
