The coexistence of smoothness and solidness in the curved structure. The beauty of ArcLine is the icing on the cake.
Sleek design
The remarkable reduction of depth with body frame adds sophisticated ambience for your place.
Protect your eyes and view in comfort
Did you know that your eyes are affected by flickers on the monitor while you may not have seen them? Over time, working, gaming and movie viewing can cause eye strain and fatigue. But, Flicker Safe and Reader Mode help maximize visual comfort by protecting your eyes from harmful blue light and reducing the flicker level to almost zero.
Immerse yourself in the game
The Black Stabilizer allows you to have better visibility, even in dark scenes.
Customize your workspace for multitasking
Screen split divides the display into multiple sections for different tasks by resizing the windows on the screen. You can work on the main screen while watching a video in a smaller window floating on the screen.
Improved color vision to color weakness
Color revision algorithms are used to help those with color weakness who have difficulty distinguishing certain ranges of colors can view all the important content.
LG 24MP58VQ - LED monitor - Full HD (1080p) - 24"
LED-backlit LCD monitor - 24"
Energy Class
Class B
Energy Consumption per Year
36 kWh
Power Consumption (On mode)
25 W
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Pixel Pitch
0.2745 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1
Response Time
5 ms (grey-to-grey)
Colour Support
16.7 million colours
Colour Gamut
72% (CIE 1976)
Input Connectors
HDMI, DVI-D, VGA
Display Position Adjustments
Tilt
Screen Coating
Anti-glare, 3H Hard Coating
Voltage
55.05 cm x 18.68 cm x 41.9 cm
3.2 kg
Environmental Standards
ENERGY STAR Qualified
Plug and Play, FCC Class B certified, UL, TUV, cUL, DDC/CI, ERP, EPA 6.0
Display Type
Energy Class
Class B
36 kWh
Diagonal Size
24"
Viewable Size
23.8"
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.2745 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1
Colour Support
Colour Gamut
72% (CIE 1976)
Response Time
5 ms (grey-to-grey)
Vertical Refresh Rate
56 - 75 Hz
Horizontal Refresh Rate
30 - 83 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
LED backlight
Picture in picture, HDCP, Picture Mode, SUPER + Resolution, On-screen Digital Controls, 4-screen split, Flicker Safe, Reader Mode, SIX Axis Control, Smart Energy Saving technology, Black Stabilizer, Response Time Control, Intelligent Auto, My Display Preset, Sleek Cut Design, Color Weakness Mode, Mega DFC
55.05 cm x 18.68 cm x 41.9 cm - with stand
3.2 kg
VGA , HDMI , DVI-D , Headphones
Mechanical
Tilt
Tilt Angle
-2/+15
Key lock
Input Voltage
25 W
Power Consumption (Typical)
26 Watt
Power Consumption Sleep
0.3 Watt
Power Consumption (Off Mode)
0.3 Watt
Windows 10
Dimensions & Weight Details
With stand - width: 55.05 cm - depth: 18.68 cm - height: 41.9 cm - weight: 3.2 kg , Without stand - width: 55.05 cm - depth: 8.55 cm - height: 33.21 cm - weight: 2.8 kg
