Public Display Mode
From channel selection to volume level, you can control the TV settings in public areas. Public Display Mode also enables you to restore default settings, as required, on the TVs.
*RS-232C Control *
Via the TV's RS-232C port, you can remotely control power and volume settings simultaneously.
WOL (Wake on LAN)
WOL (Wake on LAN) helps you remotely turn on TVs over the internet. Connect TVs and a PC in the same network, and send Magic Packet program to the MAC addresses of registered TVs. Then, it will wake up the TVs via LAN port.
Lock Mode
Lock Mode blocks external input signals with non-compliant content. This is a useful feature for preventing misuse of TVs in various facilities or public spaces.
Self Diagnosis
Self Diagnosis enables engineers and IT to engineers to analyze the data and identify technical issues quickly and easily through a USB memory device.
USB Auto Playback+
Create a media playlist of your choosing (video, music, and/or images) via USB Auto Playback+. Save it to a USB memory device, and then simply connect the USB memory device to the TV to stream your playlist sequentially.
SuperSignTM C
With SuperSign C, LG's signage management software, you can control and remotely monitor via the LAN port.
Welcome Screen (Splash Image)
Display a customized greeting message with your business name/logo on the TV when it is turned on.
USB Cloning
Clone your UV340C's with efficiency and ease. The USB Cloning feature allows you to simply copy the TV settings to all the UV340C's using a USB memory device (sold separately).
