LG G7 ThinQ
Sensuous Simplicity
Design that draws you in. Get immersed with the large 6.1" QHD+ FullVision display, all precisely engineered from metal and glass in a form that feels truly natural to hold.
Super Bright Display
Your world just got a whole lot brighter. The G7 ThinQ packs additional white pixels into the screen for stunning picture clarity and brightness—while maximizing battery efficiency.
AI CAM
The G7 ThinQ provides the creative eye, so you can get your perfect shot. AI CAM analyses subjects in your frame and provides easy recommendations on how to improve your picture.
Super Bright Camera
Get the best out of every moment with a camera so smart, that it knows when it’s too dark and automatically increases the brightness of each shot.
Portrait Mode
Take artistic pictures or self-portraits that focus on the subject and blur the background for a stunning effect—applied in real time or after the shot is captured.
Dual 16MP Cameras
Super wide-angle lens allows you to capture more of every scene, including large groups or landscapes. Plus, the G7ThinQ’s Crystal Clear Lens dramatically improves dynamic range and low-light capabilities.
Boombox Speaker
The G7ThinQ uses its inner space as a resonance chamber to amp up the bass and deliver a premium, loud, and room-filling audio experience.
Super Far Field Voice Recognition
Now all your questions and requests will be heard loud and clear. The G7ThinQ picks up your voice from even farther away and in noisy places like the car, on a boat, or when music is playing.
Mobile Phones from BT Shop
All of the mobile phones we sell here on BT Shop are unlocked and sim-free, meaning they can be used on any network. You do not need to be a BT Mobile customer to use a phone purchased from BT Shop.
If you are looking for a great SIM Only deal, or you need a new handset with a data plan, then you need to head over to bt.com now. We can connect you to fast 4G in more places than O2, Vodafone and Three, and you’ll get free, unlimited internet access at 5 million BT Wi-fi hotspots:
BT Mobile
