Share your messages clearly. Featuring high-definition displays, LG commercial LED LCD monitors offer a sleek and innovative way entertain and communicate with your guests.
LG 47LS55A 47" LED-backlit LCD display - Full HD - for digital signage
LED-backlit LCD flat panel display
Diagonal Class
47"
Commercial Use
Yes - digital signage
Titanium grey
Platform
webOS
Resolution
1920 x 1080
Display Format
1080p
Max Number of Screens
25
Video Interface
HDMI
HDMI Ports Qty
2 ports
PC Interface
DVI, DisplayPort
IPS
LCD Backlight Technology
Direct-lit LED
Image Aspect Ratio
16:9
TV Tuner
No tuner
Commercial Features
Digital signage, HTML5 support
Speaker System
Speakers not included
DVR
8 GB
USB
Remote control, IR receiver
Voltage
95 Watt
Power Consumption Stand by
1 Watt
107.1 cm x 5.58 cm x 62.16 cm
12.2 kg
Environmental Standards
ENERGY STAR Qualified
95 Watt
Diagonal Class
47"
Commercial Use
Platform
webOS
Video Processor
Dual-Core
TV Tuner
No tuner
TV Tuner Presence
No
Sensors
Temperature sensor, brightness sensor
Video Interface
HDMI
HDMI Ports Qty
2 ports
PC Interface
DVI, DisplayPort
Modes
Portrait mode, landscape mode
Dimensions
Without stand
107.1 cm
5.58 cm
62.16 cm
12.2 kg
Enclosure Colour
Titanium grey
Display
LCD Display Technology
IPS
Resolution
1920 x 1080
Display Format
1080p
Image Aspect Ratio
16:9
Direct-lit LED
Coating
Anti-reflection, 3H Hard
Colour Depth
16.7 million colours
Image Contrast Ratio
1200:1
Dynamic Contrast Ratio
500000:1
Brightness
450 cd/m²
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Response Time
11 ms
Backlight Life
50,000 hour(s)
Commercial Features
Key lock, compatible with SuperSign Software
Video Wall
25
Stands & Mounts
Flat Panel Mount Interface
400 x 400 mm
DVR
DVR
8 GB
Media Player
USB Port
USB Ports Qty
1
Remote Control
Remote control
Audio System
Audio Controls
Sound mode, balance
Speaker System
External Speakers Amplifier Power (Total)
20 Watt
On/off switch, Clear Voice II technology
Connector Type
2 x HDMI input , DVI-D input , Serial input , LAN , USB 3.0 , DisplayPort input , Serial output , DisplayPort output , Audio line-in , Remote control/ambient sensor input , Speakers output
IR receiver
HDMI cable
FCC Class A certified, UL, TUV, cUL, CB, KCC, KC, ERP
