Get a wide angle viewing experience that’s rich in color and contrast. With this IPS monitor from LG, you can enjoy brilliant picture quality, outstanding color accuracy and crisp, clear images.
Picture by picture, sRGB colour management, Eco-Mode, Digital Fine Contrast (DFC), DICOM calibrated, SUPER Energy Saving Technology, SUPER + Resolution, Auto Resolution, Multiscan Support, TrueColor Pro, 4-screen split
Matte black, matte titanium
73.67 cm x 24.14 cm x 48.35 cm - with stand
9.3 kg
Audio
Speakers - stereo - integrated
Output Power / Channel
5 Watt
2 x HDMI , USB 3.0 upstream , DisplayPort , Audio line-out , 3 x USB 3.0 downstream
Mechanical
Display Position Adjustments
Tilt Angle
-5/+15
Swivel Angle
90
Height Adjustment
140 mm
VESA Mounting Interface
100 x 100 mm
1 x HDMI cable ¦ 1 x USB cable ¦ 1 x DisplayPort cable
Backlight Life
50,000 hours
Plug and Play, UL, TUV, EN 61000-3-3, EN55024, DDC/CI, EN 60950-1:2006, EN61000-3-2:2006, EN55022:2006 Class B
Power Supply
Internal
Input Voltage
Power Consumption (On mode)
53 W
Power Consumption Sleep
0.3 Watt
Dimensions & Weight Details
With stand - width: 73.67 cm - depth: 24.14 cm - height: 48.35 cm - weight: 9.3 kg , Without stand - width: 73.67 cm - depth: 5.24 cm - height: 40.75 cm - weight: 7.3 kg
Sustainability Information
ENERGY STAR Certified
Limited warranty - 3 years - pick-up and return , Limited warranty - backlight - 3 years
