Energy Saving
Enjoy the bright screen without any image loss. Save additional energy compared to conventional LED monitors. * Conserve energy by adjusting screen brightness.
Reader Mode
By reducing blue light to protect your eyes, Reader Mode provides optimal condition for reading. With just a touch of a button, you can comfortably read on the monitor for longer periods of time without straining your eyes.
Flicker Safe
Protect your eyes from exhausting flickers and blue lights. LG's new Flicker Safe system is always on to reduce the flicker level to almost-zero. In addition, activate the Reader Mode to minimize harmful blue lights with a simple touch of a hot-key. Spend as long as you want working, gaming, or watching movies without burdening your eyes. Use the convenient and easy hot keys for more satisfaction.
Ergonomic Design
Our swivel tilting monitor has diverse swivel & tilt options ranged from 15° to 68° and from -5° to 35° respectively, to be perfectly adjusted for varied eye level and working conditions. Also, our pivot monitor can be changed to vertical anytime you want, keeping up with business situations like dealing with vertically long contents.
Built-in Power
Experience built-in adaptor which used to be assembled in the power cable. Feel how our built-in adaptor remarkably changed installation time to be a more convenient by omitting any struggles to pull it out from small size cable hole.
