LG 24M45HQ-B - LED monitor - Full HD (1080p) - 24"
LED-backlit LCD monitor - 24"
Energy Class
Class A+
Energy Consumption per Year
25 kWh
Power Consumption (On mode)
18 W
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Pixel Pitch
0.2715 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1
Response Time
2 ms (gray-to-gray), 5 ms (typical)
Input Connectors
HDMI, VGA
Display Position Adjustments
Tilt
Screen Coating
Anti-glare, 3H Hard Coating
55.6 cm x 18.8 cm x 44.5 cm
3 kg
Plug and Play, FCC Class B certified, UL, TUV, cUL, DDC/CI
Display Type
Energy Class
Class A+
25 kWh
Diagonal Size
24"
Viewable Size
23.6"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.2715 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1
Response Time
Horizontal Refresh Rate
30 - 83 kHz
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Screen Coating
Backlight Technology
LED backlight
Power off timer, Picture Mode, SUPER Energy Saving Technology, Auto Resolution, integrated cable management, Dual Smart Solution
55.6 cm x 18.8 cm x 44.5 cm - with stand
3 kg
VGA ¦ HDMI
Mechanical
Tilt
Tilt Angle
-3/+20
Power Supply
Internal
18 W
Power Consumption (Typical)
21 Watt
Power Consumption Sleep
0.3 Watt
Dimensions & Weight Details
With stand - width: 55.6 cm - depth: 18.8 cm - height: 44.5 cm - weight: 3 kg , Without stand - width: 55.6 cm - depth: 5.9 cm - height: 34.4 cm - weight: 2.7 kg
