The LG IPS Monitor ensures an awesome picture quality that provides clear images and vivid colors from any angle. LG's IPS Monitor provides accurate color for your viewing pleasure.
The 4-Screen Split feature improves productivity by simply re-sizing the windows on your screen. With one drag you can re-size one window and the other windows automatically to fir the available space. It allows from 2 to 4 windows to be shown in 8 different screen ratios without feeling cluttered.
It's easy to build up a multi-tasking environment with multiple monitors. Color Coloring APP helps you to match the color quality and brightness between two LG monitors that are connected to the same PC.
