| Quicklinx: | GTWQWS00 |
| Mfr#: | OLED55G26LA.AEK |
The pinnacle of bright beauty and sleek design
A bright new era of pixels
Heightening the vivid beauty of LG OLED self-lit pixels. Brightness Booster Max takes refinements by the a9 Gen 5 AI processor to the next level, delivering up to 30% more luminance. Now, visuals look bolder with superior light efficiency.
Beauty meets brains
The brains behind the beauty. Following deep learning advancements, LG's a9 Gen 5 AI Processor enhances objects in the foreground and background to add natural depth, and makes colours spectacularly vivid yet accurate.
Dazzling darks, luminous lights
With no backlight to dull their impact,self-lit pixels achieve the deepest blacks for crisp contrast in every light. Visuals are more defined, so you can make out subtle details your eyes usually miss.
The details set the tone
All-new Dynamic Tone Mapping Pro goes deeper to improve the picture. Previously, it elevated just the frames. Now, the technique hones in on 5000 blocks across the screen for more vivid HDR down to each last detail.
Sounds like you're in the scene
The a9 Gen 5 AI Processor up-mixes 2-channel audio into virtual 7.1.2 channel sound. Feel the action and chaos around you, just like you're the main character of the movie.
