The immersive viewing experience of the 21:9 UltraWide curved QHD display is larger than an UltraWide Full HD 21:9 monitor, and about 2.4x larger than a Full HD 16:9 monitor.
Thunderbolt 2.0
Two Thunderbolt input/output ports allow you to connect compatible devices to move data between them with incredible speed throughput in both directions.
USB 3.0 Quick Charge
Charge the battery of a connected device quickly using the USB 3.0 port. This port charges USB 3.0 Quick Charge compatible devices much faster than typical USB 2.0 cables, so waiting for a full charge doesn't hold you up.
OnScreen Control and Screen Split
OnScreen Control allows you to easily control the screen configurations and display settings to customize workspace on the screen with a few clicks of mouse. The Screen Split feature is designed to offer many on screen windows resizing options for an organized and efficient user experience.
Screen height and tilt adjustable
Thoughtful ergonomic design such as adjustable height and tilt of the display for optimal eye level assures you a comfortable work space setting.
Game Mode
Game Mode, consisting of FPS, RTS, and custom modes, provides a customized gaming experience that can be optimized to suit your favorite game genres.
LG 34UC98-W - LED monitor - curved - 34"
LED-backlit LCD monitor - 34"
Energy Class
Class B
Energy Consumption per Year
79 kWh
Power Consumption (On mode)
54 W
Curved Screen
Adaptive-Sync Technology
AMD FreeSync
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
21:9
Native Resolution
QHD 3440 x 1440 at 60 Hz
Pixel Pitch
0.2325 mm
Brightness
300 cd/m²
Contrast Ratio
5000000:1 (dynamic)
Response Time
5 ms (grey-to-grey)
Colour Gamut
99% sRGB
Input Connectors
2xThunderbolt, 2xHDMI, DisplayPort
Display Position Adjustments
Height, tilt
Screen Coating
Anti-glare, 3H Hard Coating
Voltage
AC 120/230 V
81.8 cm x 23.1 cm x 45.2 cm
7.8 kg
Environmental Standards
EPEAT Gold
FCC Class B certified, UL, BSMI, cUL, CCC, DDC/CI, ERP, EPA 6.0, EDID compatible
3-year warranty
Display Type
Energy Class
Class B
79 kWh
Diagonal Size
34"
Curved Screen
AMD FreeSync
Built-in Devices
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
21:9
Native Resolution
Pixel Pitch
0.2325 mm
Brightness
300 cd/m²
Contrast Ratio
5000000:1 (dynamic)
Colour Gamut
99% sRGB
Response Time
5 ms (grey-to-grey)
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
LED backlight
Picture in picture, picture by picture, HDCP, Picture Mode, game mode, On-screen Digital Controls, Flicker Safe, Reader Mode, SIX Axis Control, MaxxAudio, Color Calibrated, Dual Controller, Black Stabilizer, DAS Mode (Dynamic Action Sync), Response Time Control, split screen 2.0, My Display Preset, 99% sRGB colour gamut
81.8 cm x 23.1 cm x 45.2 cm - with stand
7.8 kg
Audio
Speakers - stereo
Output Power / Channel
7 Watt
2 x Thunderbolt , 2 x HDMI , DisplayPort , 2 x USB 3.0 downstream , USB 3.0 upstream
Mechanical
Height, tilt
Tilt Angle
-5/+15
Height Adjustment
110 mm
VESA Mounting Interface
100 x 100 mm
Key lock
Input Voltage
AC 120/230 V
54 W
Dimensions & Weight Details
With stand - width: 81.8 cm - depth: 23.1 cm - height: 45.2 cm - weight: 7.8 kg , Without stand - width: 81.8 cm - depth: 8.89 cm - height: 36.1 cm
