            Outstanding Color Accuracy and Wide Viewing Angle
LG IPS display supports a wide color spectrum, 99% of sRGB color gamut, and offers outstanding color and brightness with the support of VESA Display HDR™400.
Fully Use Your Desk
The compact design takes up very little desk surface and also contributes to easier installation.
Easy Connectivity
USB Type-C™ port allows from display and data transferring to connected device charging(up to 65W), enabling support for your laptop all at the same time over a single cable. It helps to boost efficiency and productivity by making a clutter-free workspace.
Incredible Speed to Victory
1ms MBR helps smooth gameplay, reducing blur and ghosting. Dynamic and fast-paced objects amidst all the action can give gamers a competitive edge.
