Protect your eyes with Reader Mode
Activate Reader Mode with a simple touch of a hot key to minimize exposure to harmful blue light. Spend as much time as you want working, playing games, or watching movies without straining your eyes. Use the convenient and easy-to-use hot keys for increased satisfaction.
Flicker Safe
Reducing the flicker level to almost zero, Flicker-Safe helps you proetect your eyes from exhausting flickers. Work and entertain as long as you want with the IPS monitor.
Colour Wizard
The Color Wizard feature prevents color-weak people from missing important content by distinguishing certain ranges of colors via the color revision algorithm.
Smart Energy Saving
LG Smart Energy Saving technology has been upgraded so that the additional energy saved besides the effect of the LED backlight, has improved. * Conserve energy by adjusting screen brightness.
