            Print either host-based or client-based output on your network-attached Lexmark laser printer. With a Lexmark card for IPDS option, use your MFP or printer for both network printing and for IBM iSeries or IBM zSeries computer jobs. Print bar codes, forms, publications and graphics closer to your end users giving you the associated cost and time savings from true distributed printing. So now direct your AFP/IPDS output using the TCP/IP protocol.
Locate your printer wherever you need it to maximize its productivity. With Lexmark's SmartSwitch auto-emulation sensing built into every Lexmark laser printer, your printer will automatically switch to the proper document language, whether it is IPDS, PostScript or PCL. Configure IPDS configuration settings using the MarkNet print server's resident web server, a browser and the printer's IP address.
