Lexar JumpDrive TwistTurn is a high-capacity USB flash drive that provides a convenient solution for storing, transferring, and sharing multimedia and more.
JumpDrive TwistTurn has a simple plug-and-play design that allows you to quickly and easily store files, so wherever you go, your information goes with you. Its durable hinged jacket rotates to easily access a USB port, and it sports an LED activity light that blinks during file transfer, so you know when the job is done. JumpDrive TwistTurn also works across platforms, giving you flexibility and ease of use.
