With a busy life on the go and so much to do, the last thing you want is to spend extra time waiting for your files to transfer. Now you can step up to the next level of performance - and take advantage of the USB 3.0 port on your new laptop or computer - with the Lexar JumpDrive S73 USB 3.0 flash drive. The drive leverages SuperSpeed USB 3.0 technology to deliver faster file transfer. Also backwards compatible with USB 2.0.
Faster File Transfer with SuperSpeed USB 3.0 Technology
With a busy life on the go and so much to do, the last thing you want is to spend extra time waiting for your files to transfer. Now you can step up to the next level of performance--and take advantage of the USB 3.0 port on your new laptop or computer--with the Lexar® JumpDrive® S73 USB 3.0 flash drive. The drive leverages SuperSpeed USB 3.0 technology to deliver faster file transfer in a range of colors and capacities from 8GB-64GB.
Convenient, Reliable Portable Storage
Store and Transfer Content Faster with SuperSpeed USB 3.0 Technology. With speeds up to 3x faster (up to 45MB/s read and 20MB/s write)* than standard JumpDrive USB 2.0 drives, the Lexar JumpDrive S73 USB 3.0 flash drive gives you the power, for example, to quickly, easily, and reliably transfer a 3GB HD video clip in less than 2 minutes (compared to less than 20 minutes using a standard USB 2.0 drive).** Leveraging the efficiencies of SuperSpeed USB 3.0 technology, it provides impressive high-speed transfer of your photos, videos, files, and more--for only slightly more than the cost of a standard USB 2.0 flash drive. And for added versatility, the drive is backwards compatible with USB 2.0 devices.
Colorful Style. Lexar JumpDrive S73 comes in a range of colorful capacity options--8GB in blue, 16GB in purple, 32GB in orange, and 64GB in green. These stylish options make it fun and easy to find one to suit your needs and reflect your personality. They also provide you with a built-in color coding system to help you organize your drives and their contents.
Designed for Convenience. Beyond its performance and good looks, JumpDrive S73 is designed for convenience. It sports a retractable connector and easy-to-use thumb slide, and also includes a key ring loop so you can easily attach it to your keychain, computer bag, backpack, or purse and go.
Lexar Performance, Quality, Compatibility, and Reliability. All Lexar memory card, card reader, and USB flash drive product designs undergo extensive testing in the Lexar Quality Labs, facilities with more than 800 digital devices, to ensure performance, quality, compatibility, and reliability. This provides customers with a high level of confidence when using Lexar products to capture, manage, move, and store the memories that matter.
Highlights
- Store and transfer content faster with SuperSpeed USB 3.0 technology
- Speeds up to 3x faster (up to 45MB/s read and 20MB/s write) than standard JumpDrive® USB 2.0 drives--at only slightly more in cost
- Colorful capacity
- Retractable connector with convenient thumb slide
- Reliably stores and transfers photos, videos, files, and more
- Compatible with PC and Mac® systems
- Three-year limited warranty
