Quickly and easily transfer and share photos, music, videos, and files between your Android tablet, smartphone, or computer with the Lexar JumpDrive M20 Mobile USB 3.0 flash drive.
No more searching for hotspots, draining your data plan, or toting clumsy cables with you on the go. The Lexar JumpDrive M20 Mobile USB 3.0 flash drive lets you move files between your On-The-Go (OTG)-enabled Android devices, or from device to computer - no data connection or power required.
The drive leverages USB 3.0 performance with up to 120 MB/s read transfer speeds. You can quickly transfer a 3 GB HD video clip in less than one minute - compared to the 4 minutes it takes using a standard USB 2.0 drive. And for added versatility, the drive is also backwards compatible with USB 2.0 devices.
