A carbon fiber roll cage with reinforcement throughout makes the X1 Carbon Ultrabook ultralight, ultradurable and highly portable. Stay unplugged all day, but when needed, boost your battery up to 80% capacity in just 35 minutes.
ThinkPad X1 Carbon offers robust security features, including ThinkShutter, which covers the front-facing HD webcam, and match-on-chip fingerprint readers with anti-spoofing technology that helps safeguard company data while providing more secure authentication and log-in.
Audio so amazing you'll think it's live
Speakers on the X1 Carbon deliver high-quality sound with Dolby Audio Premium, which energizes your entertainment with rich, powerful sound. It dynamically adjusts audio to deliver home theater quality in a virtual surround sound experience for all your entertainment. Boosted bass and enhanced volume turn it all up for sound that's loud and clear enough to share. And for times you need to plug in your headphones, enter a whole world of sound with Dolby Atmos, for an immersive experience that puts you inside the action.
Make your voice heard!
With Cortana Premium, you can speak commands to your ThinkPad X1 Carbon from 4 meters / 13 feet. The integrated 360-degree far field microphones ensure your voice is heard across the room. Wake your device with a simple phrase. Quickly and easily find files and calendar events. Even put your system into Modern Standby mode, which improves battery performance. So go ahead and speak your mind and boost your productivity at the same time.
Built to go on and on
Like all ThinkPads, the X1 Carbon is tested against 12 military-grade requirements and more than 200 quality checks to ensure they run in extreme conditions. With a chassis constructed of four layers of reinforced carbon fiber and a magnesium alloy roll-cage for added strength, you'll trust this laptop to handle whatever life throws your way.
Flick your finger for privacy
Minimize concerns about being watched or inadvertently turning on the webcam with ThinkShutter. This built-in sliding cover ensures front-facing camera privacy and security when you opt for the HD camera. It's easy to use and delivers strong protection.
2 x USB 3.0 , Mini DisplayPort , HDMI , Headphone/microphone combo jack , LAN (on supplied cable) , OneLink connector , Lenovo Ethernet extension connector
Software
Software Included
Lenovo Solution Center, Lenovo Companion, McAfee LiveSafe (30 days trial), SHAREit
