With built-in USB 3.0 hub and multiple interface options including HDMI and DisplayPort, this monitor offers versatile connectivity for a wide range of devices.
Experience stunning visuals with the 27-inch 4K IPS display, featuring a dynamic contrast ratio of 3000000:1 for deep blacks and bright whites, and wide viewing angles of 178 degrees both horizontally and vertically.
Designed with user comfort in mind, the Lenovo ThinkVision X1 allows for easy display position adjustments including tilt, ensuring a comfortable viewing experience during long work sessions.
ENERGY STAR certified and adhering to RoHS standards, this monitor is an environmentally friendly choice, consuming only 32.1 W in on mode, making it efficient without sacrificing performance.
- Lenovo ThinkVision X1 - Gen 2 - LED monitor - 4K - 27"
- LED-backlit LCD monitor - 27"
- Energy Label QR Code URL
- Https://eprel.ec.europa.eu/qr/392060
- Energy Class
- Class G
- Power Consumption (On mode)
- 32.1 W
- Microphone, USB 3.0 hub, FHD camera with LED light
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- 4K 3840 x 2160
- Pixel Pitch
- 0.1554 mm
- Brightness
- 350 cd/m²
- Contrast Ratio
- 1000:1 / 3000000:1 (dynamic)
- Response Time
- 4 ms, 6 ms, 14 ms (grey-to-grey)
- Colour Gamut
- 99% sRGB
- Input Connectors
- HDMI, DisplayPort, Thunderbolt 3
- Tilt
- Voltage
- AC 120/230 V (50/60 Hz)
- Black
- 60.974 cm x 3.27 cm x 35.171 cm
- 4.29 kg
- Localisation
- English / United Kingdom
- Environmental Standards
- ENERGY STAR Qualified
- UL, RoHS, China Energy standard Tier 2
- 3-year warranty
- Display Type
- Energy Class
- Class G
- Diagonal Size
- 27"
- Built-in Devices
- USB 3.0 hub, FHD camera with LED light
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- 4K 3840 x 2160
- Pixel Pitch
- 0.1554 mm
- Pixel Per Inch
- 163
- Brightness
- 350 cd/m²
- Contrast Ratio
- Colour Gamut
- 99% sRGB
- Response Time
- Vertical Refresh Rate
- 23 - 80 Hz
- Horizontal Refresh Rate
- 30 - 60 kHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Backlight Technology
- WLED
- Colour Temperature
- 6500K
- OSD Languages
- English, German, French, Italian, Russian, Spanish, Japanese, Chinese
- Anti-glare, Mercury free, arsenic free, 99% sRGB colour gamut
- Black
- 4.29 kg
Audio
- Speakers
Input
- Microphone
- HDMI , DisplayPort , Headphone/microphone combo jack , USB-C , 4 x USB 3.0 downstream , Thunderbolt
Mechanical
- Tilt
- Tilt Angle
- -5/+30
- Cables Included
- 1 x HDMI cable - 1.8 m , 1 x Thunderbolt cable - 1.8 m
- Localisation
- Security Slot Type
- Kensington security slot
- Input Voltage
- 32.1 W
- Power Consumption SDR (On mode)
- 32.1 kWh/1000h
- Power Consumption (Typical)
- 65 Watt
- Power Consumption Stand by
- 0.5 Watt
- Power Consumption Sleep
- 0.5 Watt
- 0.5 Watt
- OS Required
- Microsoft Windows 7 / 10
- Dimensions & Weight Details
- With stand - width: 60.974 cm - depth: 12.305 cm - height: 23.481 cm - weight: 5.59 kg , Without stand - width: 60.974 cm - depth: 3.27 cm - height: 35.171 cm - weight: 4.29 kg
Sustainability Information
- ENERGY STAR Certified
- Limited warranty - 3 years
- 0 °C
- 45 °C
- 8 - 80%
