Crisp, colorful Lenovo ThinkVision monitors improve productivity, unleash creativity and limit eye strain - and they do it with all style, and some of the simplest and cleanest cable and connectivity options in the industry.
ThinkVision T24m-29 Monitor boasts superior visual clarity and remarkable color consistency through a 1920 x 1080 FHD resolution display. Get ready for a distortion-free wide-viewing angle of up to 178° with an In-Plane Switching panel. Daisy-chain multiple devices and let the monitor's 3-side NearEdgeless bezels give you an expansive, seamless multitasking experience. Let the monitor's Smart Power2 allow for effortless plug-and-play functionality, as it dynamically detects and optimizes power distribution when multiple devices like monitors, laptops, or other USB-powered peripherals are connected.\
Convenient, comfortable, and compatible
The ThinkVision T24m-29 Monitor features a wobble-free stand with a wider lift range and tilt angle for ergonomic ease and working comfort. A compact square base fitted with a thoughtful phone holder offers enhanced convenience and frees up space on your desk. Integrated 2 x 1W speakers and clever cable management cut the clutter for a sleek look. Sit back and enjoy the convenience of an intuitive user interface provided by Lenovo exclusive software ThinkColour, which offers access to advanced display settings through an effortless and efficient user interface.
Connectivity your business can bank on
Let your business get way head, faster. Make the best of high-speed data transfers with the ThinkVision T24m-29 Monitor's full-function USB Type-C port that affords single-cable connectivity for data, video, audio, and power transfer. The ethernet port (RJ45) lets you enjoy safer, quicker remote management capabilities with PXE, WOL, and Mac Address Pass Through (MAPT) support. Free up much-needed desk space with USB Type-C with DP-Out. The ThinkVision T24m-29 Monitor also offers multiple connectivity options with USB Type-C, HDMI, and DisplayPort that enable unfettered ease.
Lenovo ThinkVision T24m-29 - LED monitor - Full HD (1080p) - 24"
LED-backlit LCD monitor - 24"
Energy Label QR Code URL
Https://eprel.ec.europa.eu/qr/1131375
Energy Class
Class D
USB 3.2 Gen 1 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080
Pixel Pitch
0.275 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 3000000:1 (dynamic)
Response Time
4 ms (extreme), 6 ms (normal)
Colour Support
16.7 million colours
Colour Gamut
72% NTSC (CIE 1931)
Input Connectors
HDMI, DisplayPort, USB-C
Built-in Ethernet
Display Position Adjustments
Screen Coating
Anti-glare
Voltage
AC 100-240 V (50/60 Hz)
Raven black
Dimensions (WxDxH) - with stand (highest position)
53.98 cm x 20.49 cm x 56.71 cm
6.1 kg
English / United Kingdom
Environmental Standards
TCO Certified Edge Displays, TCO Certified Displays 9, ENERGY STAR Qualified EPEAT Gold
Without stand - width: 53.98 cm - depth: 4.44 cm - height: 32.59 cm - weight: 3.6 kg , With stand (highest position) - width: 53.98 cm - depth: 20.49 cm - height: 56.71 cm - weight: 6.1 kg , With stand (lowest position) - width: 53.98 cm - depth: 20.49 cm - height: 41.71 cm - weight: 6.1 kg
