Equip your staff with a monitor that will help power their productivity. ThinkVision S24e-20 is an excellent performer that delivers core functionality with a sleek new form factor. Its 1920 x 1080 FHD resolution VA panel display produces vivid images to every one of your colleagues standing around the desk up to angles as extreme as 178°. The compact screen head is twice as slim as its previous generation and sits within a compact 3-side NearEdgeless frame. Place two side-by-side for a seamless visual setup without a big clumsy column breaking the scene. S24e-20 has your staff's individual comfort in mind. And tilting to the perfect angle, the modern and minimized square-based stand dials up comfort and stability while cutting down its physical footprint to give people more desk space to get the job done with clean efficiency. Then, it goes further, by incorporating a handy phone rack right inside that small square base, so that the phone is not just cleared off the desk, but it's angled perfectly for hands-free use. Cleaning up even more, the stand's built-in cable management system keeps wires out of sight and out mind. Which is a good thing because, with HDMI, VGA and Audio Out ports, S24e-20 can connect to a whole range of mission-critical devices such as PCs and even headphones. Of course, not every business scenario calls for a desk. So, with that in mind, you can mount this monitor on the wall through its 100 mm x 100 mm VESA mount capability, which will also hold a Lenovo Tiny or Nano PC discreetly behind the screen. And because your staff are your most precious asset, S24e-20 has TÜV Rheinland Eye Comfort Certified technology to protect them from eye fatigue.
