If your business is moving up from a desktop environment to its first server, you'll find everything you need in the TS140 - an affordable, durable server with impeccable productivity and manageability features.
The TS140 makes clever use of Intel AMT 9.0 to provide out-of-band, cost-effective, remote management of end-user environments - regardless of the managed server's status. Intuitive and secure, the web console works directly out of the box to give point-and-click management tools perfect for branch offices or remote deployments with limited IT resources.
At 26 dB, the acoustics of the TS140 are impressively quiet for any server - that's less noise than you'll find in a typical library. Plus, it's ENERGY STAR-certified, so it's easy on the environment and easy on your power bills.
