The ThinkPad X395 easily slips into a bag or tucks under your arm. It's powered by a fast processor, which means longer battery life, faster processing, and higher power efficiency.
2nd Gen AMD Ryzen Pro APU and Vega graphics increase CPU frequency and improve GPU performance. With AMD power, your ThinkPad X395 runs more efficiently and enhances battery life and audio performance. And with AMD FreeSync, available on the FHD display, stuttering and tearing are eliminated, and dynamic frame rates are optimized-you'll enjoy videos and gaming all the more.
Displays that dazzle
Choose from several display options, including an FHD IPS on-cell touchscreen for enhanced battery life, an FHD IPS non-touch screen, and an HD TN display. No matter which choice you make, the super-slim bezel design adds a sleek look to your ThinkPad X395.
Tested for battle, built for life
Like all ThinkPads laptops, the X395 is tested against 12 military-grade requirements and more than 200 quality checks to ensure they run in extreme conditions. From the Arctic wilderness to desert dust storms, from zero gravity to spills and drops, you can trust this laptop to handle whatever life throws your way.
Battery life that keeps up with you
When you're on the go, you can't be worried about finding electrical outlets. That's why the ThinkPad X395 delivers up to 14.5 hours of battery life. And if you're running low, Rapid Charge technology provides 80% capacity in just an hour. So with a 60-minute layover, you can easily boost your battery up to more than 11.5 hours.
A laptop that's well connected
Whether you're on the go or working at your desk, the X395 keeps you online with the optional LTE-A card. This WWAN technology lets your laptop function like a smartphone-where there's cellular service you can always jump online, even if there's no WiFi available. And you can trust that your connection is secure.
Gigabit Ethernet via optional Ethernet (RJ-45) adapter
DASH
Lithium Ion
48 Wh
Run Time
Up to 14.5 hours
AC Adapter
Input
Output
65 Watt
Connections & Expansion
USB 3.1 Gen 2 , USB 3.1 Gen 1 (Always On) , 2 x USB-C 3.1 Gen 2 (supports DisplayPort Alt Mode) (Power Delivery) , Headphone/microphone combo jack , HDMI , Lenovo Ethernet extension connector , Dock
