Starting at just 3 lbs and 0.67" (17 mm) thick, this laptop is ultraportable. It fits neatly in your backpack, briefcase or tote - it's perfect for productivity on the go. And with up to 10 hours of battery life, you can go all day without recharging.
PC performance has never been faster. Intel 6th Gen Core i processors with built-in security are designed to take your productivity, creativity, and 3D gaming to the next level. Intel vPro Technology makes enterprise-level manageability even more convenient and efficient. Fitting a variety of budgets, it's also very easy to use. So you can get more done right from the start.
