Quicklinx: | FPSQWS00 |
Mfr#: | 10S6003JUK |
Make IT's jobs easier
The ThinkCentre M920z makes life easy for your IT team, keeping your enterprise data safe via embedded Trusted Platform Management (TPM) 2.0 data encryption, BIOS-based Smart USB protection, Windows Hello support, and an intrusion switch that sends alerts if someone attempts to open the chassis. It’s also quick and easy to deploy.
Gets your numbers up
Users can expect high responsiveness and seamless multitasking of even the most intensive tasks, thanks to the latest generation of Intel Core processor and PCIe SSD on selected models, not to mention the fast data transfers of its USB 3.1 Gen 2 and USB-C ports. Watch your employees’ productivity soar.
Keeps your data secure
Rest assured your data will stay safe, thanks to Trusted Platform Module (TPM) 2.0 data and password encryption. And its BIOS-based Smart USB Protection lets you configure the USB ports to respond only to specific devices, preventing unauthorized copying of files.
Save space…
The compact footprint of the M920z AIO means it will leave your workspace clutter-free and open for business. It’s also VESA-mountable and borderless, and can use an optional stand to save even more space.
…and save time
With the Keyboard Power On feature, you can switch on the M920z directly from its keyboard. Its Smart Webcam rotates 180 degrees horizontally and 50 degrees vertically, so a user can switch from front to rear camera mode and keep video conferences moving along.
Tested to extremes
The M920z is tested for durability against eight MIL-SPEC standards: low pressure (altitude); vibration; high temperature; low temperature; sand/dust; temperature shock; humidity; and shock. Yes, this AIO is reliable.
Easy on the eyes
The M920z display’s antiglare panel scatters light and stays flicker-free, reducing eye strain. Plus, its Eye Comfort and Low Blue Light certifications ensure your eyes will stay comfortable when working those long hours.
