For large businesses (EDU/GOV/PUB etc.) with a need for a high-performance desktop PC, the ThinkCentre M900 provides the latest Intel technology without sacrificing security, stability, manageability and environmental friendliness.
ThinkCent?r M900 Tiny is an ultra-small form factor. It offers mounting solutions, including support for standard VESA mounts and Tiny-in-One configurations - which transform your PC into a space-saving modular all-in-one. Tiny desktops fit just about anywhere, while still delivering reliable performance.
Intel vPro-ready
The M900 Tiny includes vPro technology to make enterprise-level manageability even more convenient and cost-efficient. The built-in management capabilities of vPro allow IT administrators to access your PC remotely, even when the system if powered off, to diagnose and repair systems and automate security patches and updates - ensuring your system is always up and running.
Stable Image Platform Program
Stable Image Platform Program (SIPP) facilitates the often tricky process of transitioning from one technology generation to the next.
Multiple monitor support
Maximize productivity with independent display support for up to three monitors. The expanded work area and easier navigation between applications help reduce errors and improve productivity as you extend your desktop across multiple monitors.
Keyboard power-on support
If you choose to mount this compact unit on the back of your monitor, you can still power on conveniently from the front, by simply pressing Alt+P on a USB-connected keyboard.
Fast data transfer
Move data between the M900 Tiny and other devices quickly with USB 3.0 - it's extremely fast.
Variety of I/O support
No matter your port needs, this desktop has you covered, with support for USB 3.0, DisplayPort, VGA, HDMI, LAN, and serial connections.
