The ThinkCentre M73z 20-inch all-in-one gives your enterprise powerful performance and strong security in a sleek, space-saving package. Do business the ThinkCentre all-in-one way.
Reclaim your desk and reduce the amount of space needed by up to 80 percent, compared to traditional desktop configurations. The integrated power supply means one cable is all you need, cutting down on clutter. And this all-in-one includes an ergonomically designed VESA mount and multiple stand offerings, for maximum user comfort from a compact footprint.
Solid security and manageability
The M73z offers some of the best security tools available in the industry, including USB ports disablement to help prevent data theft and network security risks against unauthorized use of storage devices. Trusted Platform Module (TPM) encrypts data and key information like passwords and digital certificates, further securing applications, electronic transactions, and online communication.
Physical camera switch
Lock the webcam, for guaranteed privacy while working or conferencing.
SuperSpeed USB 3.0
Enables up to 10 times faster file transfer, allowing for lightning-fast copying of large media files, as well as seamless connections between audio- and video-related peripherals. Backward-compatible with USB 2.0 devices.
View management utility
Take advantage of multiple active displays, and enjoy faster multitasking - the expanded work area and easier navigation between applications helps reduce errors and improve productivity as you extend your desktop across multiple displays.
ENERGY STAR certification
Save energy and reduce your power consumption costs - good for the environment and your bottom line.
Personal computer - all-in-one - administrator password, hard drive password, power-on password, boot without keyboard or mouse, USB port control, boot sequence control, chassis intrusion detection, tilt adjustment, carrying handles
Microsoft Windows 7 Professional 64-bit Edition (downgrade from Windows 8.1 Pro 64-bit) + Windows 8.1 Pro 64-bit Licence
Software Included
CyberLink PowerProducer, CyberLink Power2Go, ThinkVantage Rescue and Recovery, Adobe Reader, Skype, ThinkVantage System Update, Norton Internet Security (30 days subscription), ThinkVantage Product Recovery, Lenovo Message Center Plus, EverNote, ThinkVantage Communication Utility, ThinkVantage View Management Utility, Lenovo Solution Center, ThinkVantage Automatic Lock Utility, Lenovo Cloud Storage by SugarSync, Password Manager, Intel AppUp Center, Nitro Pro, Lenovo Desktop Power Manager, ThinkVantage Device Experience
Business black
50.6 cm x 9.05 cm x 40.475 cm
7.46 kg
Manufacturer Selling Program
TopSeller
Environmental Standards
ENERGY STAR Qualified
Limited warranty - 1 year - on-site - response time: next business day
Personal computer
Product Form Factor
All-in-one
Built-in Devices
Stereo speakers
Embedded Security
Trusted Platform Module (TPM 1.2) Security Chip
Business black
Processor / Chipset
CPU
Intel Pentium G3240
Clock Speed
3.1 GHz
Number of Cores
Dual-Core
CPU Qty
1
Max CPU Qty
1
CPU Socket
LGA1150 Socket
Chipset Type
Intel H81
Cache Memory
Installed Size
3 MB
Cache Per Processor
3 MB
RAM
Installed Size
4 GB / 16 GB (max)
DDR3L SDRAM
Effective Memory Speed
1600 MHz
Rated Memory Speed
1600 MHz
Memory Specification Compliance
PC3-12800
SO-DIMM 204-pin
Slots
2 (Total) / 1 (empty)
Configuration Features
1 x 4 GB
Hard Drive
HDD
1 x 500 GB
Interface Type
SATA 6Gb/s
Spindle Speed
7200 rpm
Storage Controller
1 x SATA - integrated
Controller Interface Type
SATA 6Gb/s
Optical Storage
DVD-Writer - SATA
Card Reader
7 in 1 card reader
Monitor
Monitor Type
LED
Diagonal Size
20"
Native Resolution
1600 x 900 (HD+)
Widescreen Display
Image Aspect Ratio
16:9
Image Brightness
250 cd/m²
Image Contrast Ratio
1000:1
Graphics Controller
Integrated
Graphics Processor
Intel HD Graphics
Video Interfaces
VGA
Audio Output
Integrated
Sound Output Mode
Stereo
High Definition Audio
Speakers Included
2 x right / left channel
Input Device
Mouse, keyboard
Keyboard
Keyboard Name
Preferred Pro USB
USB
Localization & Layout
Mouse
Optical
USB
Ethernet Controller
Intel I217-V
Wireless LAN Supported
Wireless NIC
Intel Wireless-N 7260
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, Bluetooth 4.0
Slots
1 (total) / 0 (free) x PCIe Mini Card , 2 (total) / 1 (free) x SO-DIMM 204-pin , 1 (total) / 0 (free) x CPU
2 x USB 3.0 (2 in front) , 1 x microphone (1 in front) , 1 x headphones (1 in front) , 4 x USB 2.0 , 1 x LAN (Gigabit Ethernet) , 1 x VGA
Lenovo recovery disk flyer
Administrator password, hard drive password, power-on password, boot without keyboard or mouse, USB port control, boot sequence control, chassis intrusion detection, tilt adjustment, carrying handles
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
VESA Mounting Interface
100 x 100 mm
RoHS, GREENGUARD, EuP
TopSeller
Power supply
Power Provided
150 Watt
Efficiency
85%
Operating System / Software
OS Provided
Microsoft Windows 7 Professional 64-bit Edition (available through downgrade rights from Windows 8.1 Pro 64-bit) + Windows 8.1 Pro 64-bit Licence
Software
Sustainability Information
ENERGY STAR Certified
