The ThinkCentre M710e small form factor doesn't scrimp on performance. Super compact, this entry-level PC offers robust security features to safeguard your data, powerful performance with high processing, and improved platform stability.
The ThinkCentre M710e features a tool-free chassis, which means that if IT admins ever need access, it's sure to be quick and easy. The M710e delivers powerful security options that safeguard your organization's data. With Trusted Platform Module (TPM) firmware, data is encrypted. Smart USB protection enables ports to be individually defined and blocked, so would-be thieves are thwarted if they try to download information. Plus smart cable block enables locking of all wired peripherals that are attached to the M710e - once the block is clipped on, it can only be removed from the inner side of the chassis. What more could an IT administrator ask for!
Big on power
Powered by the excellent processor, the ThinkCentre M710e SFF is designed for speed, responsiveness, and efficiency - three key features that can help propel your business.
Lock slots for physical security
The M710e features lock slots for physical security too: a pad lock slot prevents removal of the back cover, while a Kensington lock slot enables it to be secured to a workstation.
4 x USB 3.1 Gen 1 (2 front, 2 rear) , 1 x microphone , 1 x headphones/microphone (1 in front) , 2 x USB 2.0 , 1 x serial , 1 x LAN (Gigabit Ethernet) , 1 x VGA , 1 x DisplayPort , 1 x audio line-out
