This 19.5 inch All-In-One combines the simplicity of Android with the power and productivity of a home computer. Use apps on the big screen, with much more storage than smaller Android devices, plus an integrated battery for in-home mobility. Enjoy the intuitive operation of Android Jelly Bean 4.2.2 - with thousands of productivity and entertainment apps readily downloadable via Google Play - on a larger scale than typical Android devices. You'll also benefit from multi-user support, allowing you and your friends and family to have separate user profiles.
The gorgeous 250-nit HD+ display yields bright, detailed visuals, and the 2-point infrared multitouch capability is the same responsive, accurate technology we offer in our Windows 8 All-in-One PCs.
With up to 500GB HDD storage, you won't have to worry about where to put all your data, videos, music or photos. Enjoy the convenience of an Android device, with much more storage capacity. This processor is powered by an NVIDIA GeForce GPU with 72 custom cores and ARM's most advanced CPU core yet, plus a second-generation battery-saver core. Delivers record performance and battery life. With the webcam and two 2W stereo speakers, you'll enjoy web chats like you're really there. And like smaller Android devices, the ambient and gravity sensors will detect changes in orientation, lighting, etc. and adjust accordingly. Quickly attach extra storage or transfer multimedia using the easily accessed USB 2.0 ports and 6-in-1 card reader on the side of the PC.
