For large businesses (EDU/GOV/PUB etc.) with a need for a high-performance desktop PC, the ThinkCentre M900 provides the latest Intel technology without sacrificing security, stability, manageability and environmental friendliness.
ThinkCent?r M900 Tiny is an ultrasmall form factor. It offers mounting solutions, including support for standard VESA mounts and Tiny-in-One configurations - which transform your PC into a space-saving modular all-in-one. Tiny desktops fit just about anywhere, while still delivering reliable, enterprise-level performance.
Intel vPro -ready
The M900 Tiny includes Intel vPro technology to make enterprise-level manageability even more convenient and cost-efficient. The built-in management capabilities of Intel vPro allow IT administrators to access your PC remotely, even when the system if powered off, to diagnose and repair systems and automate security patches and updates - ensuring your system is always up and running.
Stable Image Platform Program
Intel's Stable Image Platform Program (SIPP) facilitates the often tricky process of transitioning from one technology generation to the next.
Multiple monitor support
Maximize productivity with independent display support for up to three monitors. The expanded work area and easier navigation between applications help reduce errors and improve productivity as you extend your desktop across multiple monitors.
Keyboard power-on support
If you choose to mount this compact unit on the back of your monitor, you can still power on conveniently from the front, by simply pressing Alt+P on a USB-connected keyboard. Also compatible with wireless keyboards.
Fast data transfer
Move data between the M900 Tiny and other devices quickly with USB 3.0 - it's up to 10 times faster than previous USB technologies, and is backward-compatible.
Tested to military specifications
Military-specification testing validates the ruggedness, durability, and quality of this PC by testing against multiple parameters.
Variety of I/O support
No matter your port needs, this desktop has you covered, with support for USB 3.0 (including fast charge), DisplayPort, VGA, HDMI, LAN, and serial connections.
Microsoft Windows 7 Professional 64-bit Edition (downgrade from Windows 10 Pro 64-bit) + Windows 10 Pro 64-bit Licence
33.8 cm x 35.7 cm x 8.8 cm
9 kg
Limited warranty - 3 years - on-site
Personal computer
Product Form Factor
Small form factor
Built-in Devices
Speaker
Processor / Chipset
CPU
Intel Core i5 (6th Gen) 6500
Clock Speed
3.2 GHz
Max Turbo Speed
3.6 GHz
Number of Cores
Quad-Core
CPU Qty
1
Max CPU Qty
1
Processor Main Features
Intel Turbo Boost Technology 2
CPU Socket
LGA1151 Socket
Chipset Type
Intel Q170
Cache Memory
Installed Size
6 MB
Cache Per Processor
6 MB
RAM
Installed Size
4 GB / 64 GB (max)
DDR4 SDRAM - non-ECC
Effective Memory Speed
2133 MHz
Rated Memory Speed
2133 MHz
Memory Specification Compliance
PC4-17000
DIMM 288-pin
Slots
4 (Total) / 3 (empty)
Unbuffered
Configuration Features
1 x 4 GB
Hard Drive
Hybrid Drive
1 x 500 GB (8 GB cache)
Interface Type
SATA 6Gb/s
Spindle Speed
5400 rpm
Storage Controller
1 x SATA
Controller Interface Type
SATA 6Gb/s
Optical Storage
DVD-Writer - SATA
Monitor
Monitor Type
None.
Graphics Controller
Graphics Processor
Intel HD Graphics 530
Video Interfaces
VGA, DisplayPort
Input Device
Mouse, keyboard
Keyboard
USB
Localization & Layout
Mouse
Optical
USB
Bays
1 (total) / 0 (free) x external 5.25" Slim Line , 1 (total) / 0 (free) x internal 2.5" x 1/8H
Slots
4 (total) / 3 (free) x DIMM 288-pin , 1 (total) / 0 (free) x CPU
8 x USB 3.0 (2 front, 6 rear) , 2 x microphone (1 front, 1 rear) , 1 x headphones (1 in front) , 1 x LAN (Gigabit Ethernet) , 1 x VGA , 2 x DisplayPort , 1 x audio line-in , 1 x audio line-out , 2 x USB 2.0 (2 in front)
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
Power supply
Power Provided
210 Watt
Efficiency
85%
Operating System / Software
OS Provided
Microsoft Windows 7 Professional 64-bit Edition (available through downgrade rights from Windows 10 Pro 64-bit) + Windows 10 Pro 64-bit Licence
