Featuring a streamlined chassis with a polished aluminum cover, the Ideapad 330S is designed to make an impression. Choose from a range of sophisticated tone-on-tone color options to make it yours. Designed with you in mind We've placed the power button back on the upper right-hand side of the keyboard for quick access-and added a backlit numeric keyboard option for ease of use.
Amp up your productivity
The latest generation of Intel Core i7 processing offers up to a 40 percent improvement in performance,* with unprecedented gaming capabilities, theater-like entertainment, faster boot-ups, and seamless multitasking.* Software and workloads used in performance tests may have been optimized for performance only on Intel microprocessors. Performance tests are measured using specific computer systems, components, software, operations, and functions. Any change to any of those factors may cause the results to vary. Accelerated graphics performance Upgrade with a NVIDIA GeForce GTX1050 discrete graphics card, powered by NVIDIA Pascal with up to 3 times the performance of previous generations. Also offering AMD Radeon 530 and AMD Radeon 535.
Rapid Charge, any time
We know you've got stuff to do-who wants to be chained to an outlet? The Ideapad 330S not only boasts up to 7 hours of battery life, it also offers Rapid Charge: 15 minutes plugged in will give you up to 2 hours of battery life.* Charge up quickly, and get back to your day.*In power-off mode. 65 W power supply required.Windows 10 keeps getting better Leverage the best of Windows 10, with a new update packed with exciting features. The powerfully reimagined Photos app makes it easier-and more fun-to tell your story in video: add a soundtrack, use transitions, deploy 3D effects, and more. And sharing is quicker than ever, with intuitive settings that make it easier to instantly connect with the people you care about most.
Cleaner, safer preload
We are committed to providing an uncluttered desktop and a safer PC experience out of the box. Our preload contains just five hand-selected applications designed to increase your productivity. Lifelike clarity Featuring up to FHD resolution on a wide-angle display edged with razor-thin 5.9 mm bezels, the Ideapad 330S offers the dynamic experience of a portable home theater.
Rich, warm sound of Dolby Audio
With Dolby Audio, the Ideapad 330S dramatically enhances your entertainment experience. Turn up the volume without distortion-you'll hear every detail. Ample storage for your photos, movies,& more The Ideapad 330S can be customized to fit all your storage needs: Up to 2 TB SATA HDD stores thousands of videos, photos and files. A responsive PCIe SSD-up to 256 GB-features shorter boot-up times and faster data transfer speeds. And 128 GB PCIe SSD + 1 TB SATA HDD hybrid storage offers the best of both options.
