Meet the Ideapad 330S. Thinner & lighter with narrow bezels for broader viewing, it boasts state-of-the-art processing and accelerated graphics performance. Power through any task with ease.
Featuring a streamlined chassis with a polished aluminum cover, the Ideapad 330S is designed to make an impression. Choose from four sophisticated tone-on-tone color options to make it yours. Keep moving With up to seven hours* of battery life, the Ideapad 330S will easily go wherever your day takes you.*Based on testing with MobileMark 2014. Battery life varies significantly with settings, usage,& other factors.
Amp up your productivity
The latest generation of Intel Core i7 processing offers up to a 40 percent improvement in performance,* with unprecedented gaming capabilities, theater-like entertainment, faster boot-ups, and seamless multi-tasking.*Software and workloads used in performance tests may have been optimized for performance only on Intel microprocessors. Performance tests are measured using specific computer systems, components, software, operations, and functions. Any change to any of those factors may cause the results to vary. Accelerated graphics performance Select models of the Ideapad 330S boast powerful, discrete AMD Radeon graphics. Discrete graphics cards rely on their own processing power, so you'll experience smoother graphics, less screen tearing, and better gaming performance without compromising overall speed and responsiveness. Whether you're playing a game or creating or editing content, you'll enjoy crisp visuals.
Rapid Charge, any time
Running out of battery and short on time? The Ideapad 330S supports Rapid Charge-15 minutes plugged in will give you up to 2 hours of use.* You'll also be able to charge your phone and other devices via USB 3.0 port, even when your laptop is powered off. Make the most of your time.*In power-off mode. 65 W power supply required. Windows 10 keeps getting better Leverage the best of Windows 10, with a new update packed with exciting features. The powerfully reimagined Photos app makes it easier–and more fun-to tell your story in video: add a soundtrack, use transitions, deploy 3D effects, and more. And sharing is quicker than ever, with intuitive settings that make it easier to instantly connect with the people you care about most.
Cleaner, safer preload
We are committed to providing an uncluttered desktop and a safer PC experience out of the box. Our preload contains just five hand-selected applications designed to increase your productivity. Lifelike clarity Featuring up to FHD resolution on a wide-angle display edged with razor-thin 5.7 mm bezels, the Ideapad 330S offers the dynamic experience of a portable home theater.
Rich, warm sound of Dolby Audio
With Dolby Audio, the Ideapad 330S dramatically enhances your entertainment experience. Turn up the volume without distortion-you'll hear every detail. Ample storage for your photos, movies,& more The Ideapad 330S can be customized to fit all your storage needs: Up to 2 TB SATA HDD stores thousands of videos, photos, and files. A responsive SATA or PCIe SSD– up to 256 GB– features shorter boot-up times and faster data-transfer speeds. And 128 GB PCIe SSD + 1 TB SATA HDD hybrid storage gives you a good mix of both.
