Up to 5th Generation Intel® Core™ Processors
The new standard for PC performance has arrived with Intel® 6th Gen Core™ processors. This blazing fast, feature-packed processor family with built-in security is ready to take your productivity, creativity, and 3D gaming to the next level. What's more, by enabling the exciting Windows 10 features, 6th Gen Intel Core processors empower you to unleash your imagination and explore the possibilities.
Up to Windows 10 Home
Windows 10 Pro is designed to empower you and your business. It allows you to do great things across your devices securely with anyone, anywhere, and at any time. Fitting a variety of budgets, it's also very easy to use. So you can get more done right from the start.
Comfortable Viewing
The HD anti-glare display helps reduce eye fatigue, allowing you to work longer in comfort.
Thin and Light Design
Starting at a mere 2.3kg and just 22.9mm thick, the Lenovo B50 laptop is ready for productivity on the go.
Extra Peace of Mind
You can rest assured knowing your hardware is protected, thanks to the Kensington® Minisaver Cable Lock.
Connectivity Options
With 802.11 bgn WiFi and optional Bluetooth® 4.0, you can connect to the Internet wherever you go.
Integrated Webcam
The 0.3M webcam and microphone will help you enjoy web conferences or online video chats like you're really there.
Fast Data Transfer
Move data between the Lenovo B50 and other devices quickly with USB 3.0. Up to ten times faster than previous USB technologies, it's also backward-compatible.
Ample Storage
With storage up to 1TB HDD, you won't have to worry about where to put all your data, videos, music, and photos.
HDMI Port
Stream content quickly and easily from your Lenovo B50 to a television or other display.
