Optimized for safeguarding essential data while on-the-go, the ThinkPad USB 3.0 1TB Secure Hard Drive offers high-level 256-bit Advanced Encryption Standard (AES) security within a slim, lightweight, self-powered, easy-to-use design.- Connectivity via either USB 2.0 or USB 3.0 (2) interface
- Compact size
- No requirement for an ac power adapter
- Driverless operation under Microsoft Windows 7, Windows XP and Vista
- All stored data is fully encrypted using the AES 256-bit security encryption algorithm
- Real-time encryption with no read/write speed impact
- Shock-mounted 1TB 5400 rpm hard drive capacity
- Built-in USB 3.0 cable with an integral storage slot
- Integrated high quality metal dome switch keypad for entering an 8 to 16 digit password for 1 user ID and 1 administrator ID
- USB Y extension cable to ensure adequate power
- Attractive protective carrying case
- Non-skid anti-vibration pads
- High quality ThinkPad soft touch paint
- Multi-colored LED device status indicator
The ThinkPad USB 3.0 1TB Secure Hard Drive option also enables
- Easy and secure storage expansion
- No software installation and no power adapter required for operation
- Built-in administrative password management
- Simple file backup
