LaCie wireless space - Design By Neil Poulton Network-Attached Storage -- Unattached at Last
Wireless Storage The LaCie Wireless Space takes network-attached storage to the next level by implementing Wi-Fi technology, making it easy for you to access your files, no matter where they are in your house. It has three pre-configured modes that allow you to create a Wi-Fi access point, a Wi-Fi Ethernet extender to connect your printers or computers, or you can even use it as a Gigabit router. Keep It All Organized Even if you already have a Wi-Fi modem, you can use the LaCie Wireless Space as wireless storage; with capacities of 1 and 2TB, it holds all of your music, movies, and photos, helping you to access them on any computer on your home network. Backing up your files wirelessly, whether on a PC and a Mac® (and the Wireless Space is Time Machine® compatible) helps you save space and cuts down on the number of cables you have to use, saving you hassle and resources. Replace Your Cable Box With static and dynamic port forwarding and PPoE connections, the Wireless Space performs even better than your cable router thanks to Wi-Fi n and Gigabit Ethernet performance. You can even stream movies from the Wireless Space to any UPnP™/DLNA® compatible device, and works in tandem with iTunes®. Now, it's simple to organize your files in a central location and play them on all your devices. Extraordinary Design Designed exclusively for LaCie by Neil Poulton, the compact Wireless Space has a sophisticated, understated style. Its elegant, unobtrusive presence blends beautifully into your multimedia setup. This sleek network hard disk has a fashionable, mirrorpolished black finish with two unique distinguishing features--a cool, blue LED strip on its underside that creates an ambient glow, and a touch-sensitive WPS button. Its smartly engineered design
Box Content
Minimum System Requirements
