The LaCinema Classic HD provides uncompromising quality, adding stunning 1080p playback through HDMI on your HDTV. No matter the video, music or photo format and resolution, the LaCinema Classic HD will play it seamlessly with the highest sound and image quality. It's compatible with all the most popular video formats on the market, from DivX, MKV, to AVC and H.264, and provides uncompromised Dolby Digital quality sound.
It's easy to play your movie library on your HDTV: connect the LaCinema Classic HD to your computer to store your movies then connect it to your TV for instant playback. No configuration is required.
UPnP /DLNA capabilities also ensure that the LaCinema Classic HD works in tandem with your home network, connecting easily to your PC or network storage (like a LaCie Network Space) so it's simple to populate with your media. In a snap, you can play all of your media - no matter where it's stored.
The LaCinema Classic HD can also be turned into a powerful media server that will allow you to use it as a central location for all of your media. You can even share content with a Playstation or Xbox, with the LaCinema Classic HD functioning as your primary media player.
You can store your entire digital media library in one location. This user-friendly media player is quiet and fanless, and adds sophisticated style to your home. A user-friendly navigation and remote control have been made to enhance your entertainment experience. You can even quickly connect a USB storage key to the front of your LaCinema Classic HD to instantly watch movies on your TV.
