LaCie Rikiki SuperSpeed USB 3.0 1TB The World's Smallest USB 3.0 Mobile Drive The LaCie Rikiki USB 3.0 combines the fastest interface on the market with perfect portability. The tough aluminum casing combines form and function; it withstands bumps and jolts, but its sophisticated style sets it apart from other mobile hard drives. With interface speeds up to 5Gb/s and capacities available up to 1TB, it offers desktop-sized storage in a pocket-sized product. Best of all, it's backward-compatible with USB 2.0, which means connectivity is never an issue. - Ultra-small
- Ultra-fast USB 3.0 performance
- Huge capacity up to 1TB
- Made of resistant aluminum
Specifications - Capacity: 1TB
- Interface: USB 3.0 (USB 2.0 compatible)
- Transfer Rate: USB 3.0: up to 5Gb/s (600MB/s); USB 2.0: up to 480Mb/s (60MB/s)
- Dimensions (WxDxH): 75 x 118.5 x 13.4 mm / 2.9 x 4.6 x 0.52 in.
- Weight: 176 g / 6.2 oz.
- Warranty: 2-year limited
Minimum System Requirements - Computer with a USB 3.0 or USB 2.0 port
- High-speed Internet for online storage
- Latest version of Windows® XP, Windows Vista®, Windows 7 / Mac® OS X 10.5, 10.6
- Minimum free disk space: 600MB recommended
Software - LaCie Setup Assistant, LaCie Backup Assistant (PC and Mac),
- Wuala 10GB Online Storage (1 year included)
Box Content - LaCie Rikiki USB 3.0
- USB 3.0 cable (USB 2.0-compatible)
- Quick Install Guide
