The perfect complement to SSD-based laptops and all-in-one computers, the LaCie d2 Thunderbolt 3 massively upgrades your capacity for professional bandwidth-intensive creative applications.
Experience fast data transfer with interface speeds up to 40 Gbps (Thunderbolt 3) and 5 Gbps (USB 3.0), ensuring efficient workflow and reduced wait times.
Expansive storage capacity
With a generous 10 TB capacity, this external hard drive meets the demands of extensive storage requirements, making it suitable for professionals and enthusiasts alike.
Versatile connectivity
Equipped with both Thunderbolt 3 and USB 3.1 Gen 1 interfaces, this hard drive offers flexible connection options to both Mac and PC users, enhancing compatibility across devices.
Durable design
Crafted from aluminum, the LaCie d2 Thunderbolt 3 hard drive has a robust and reliable construction that not only ensures longevity but also complements any workspace aesthetic.
Seamless integration
Designed for desktop use, this external hard drive integrates seamlessly into your workspace, supported by an included AC adapter for reliable power supply.
LaCie d2 Thunderbolt 3 - hard drive - 10 TB - USB 3.1 Gen 1 / Thunderbolt 3
Hard drive - external (desktop)
10 TB
USB 3.1 Gen 1 / Thunderbolt 3 - USB-C
Data Transfer Rate
40 Gbps (Thunderbolt 3) / 5 Gbps (USB 3.0)
Enterprise
Power Source
Included AC adapter
21.7 cm x 13 cm x 6 cm
2.2 kg
5-year warranty
10 TB
Enterprise
21.7 cm
13 cm
6 cm
2.2 kg
Performance
Interface Transfer Rate
Max Data Transfer Rate
240 MB/s
Expansion & Connectivity
1 x USB 3.1 Gen 1 - 24 pin USB-C , 2 x Thunderbolt 3 - 24 pin USB-C
Power Source
Included AC adapter
Power adapter
Windows 8 or later, Apple macOS Sierra 10.12 or later
1 x USB-C to USB-A cable - external , 1 x Thunderbolt cable - external
