With interfaces for Gigabit Ethernet, USB 2.0, and USB host, alongside AirPrint Enabled for seamless mobile printing, this printer offers versatile connectivity options for any office environment.
High-capacity printing
Boasting a maximum media capacity of 2100 sheets and supporting a wide range of media sizes from A4 to Legal, the Kyocera ECOSYS P7240cdn is designed to handle large print jobs with ease, making it suitable for busy workgroups.
Superior print quality
Achieve high print quality with resolutions up to 1200 x 1200 DPI for both black and white and color documents, ensuring crisp, clear, and vibrant outputs every time.
Rapid output speeds
Experience efficiency with first print out times as fast as 5.5 seconds for black and white and 6.5 seconds for color, enabling you to get your documents printed quickly without sacrificing quality.
Eco-friendly technology
Leveraging Kyocera ECOSYS Technology, this printer not only delivers reliable performance but also promotes environmental sustainability with lower power consumption and a durable design that reduces waste.
Up to 40 ppm - B/W - A4 (210 x 297 mm) , Up to 40 ppm - colour - A4 (210 x 297 mm) , Up to 36 ppm - duplex - A4 (210 x 297 mm)
Max Resolution (B&W)
1200 x 1200 dpi
Max Resolution (Colour)
1200 x 1200 dpi
Automatic Duplexing
USB 2.0, Gigabit LAN, USB host
AirPrint Enabled
Cortex-A9 1.2 GHz
RAM Installed (Max)
1 GB (3 GB)
Card Reader
Language Simulation
PCL 5C, PostScript 3, PCL 6, PCL XL, KPDL3, XPS, PRESCRIBE IIc, PDF Direct
Media Type
Plain paper
Total Media Capacity
600 sheets
Media Handling
100-sheet multipurpose tray, 500-sheet input tray
Print server
Printer Features
39 cm x 53.2 cm x 46.95 cm
Printer Type
Workgroup printer - laser - colour
Printer
Print Speed
Wired
AirPrint Enabled
1200 x 1200 dpi
1200 x 1200 dpi
Automatic Duplexing
PostScript Support
Standard
First Print Out Time B/W
5.5 sec
First Print Out Time Colour
6.5 sec
Language Simulation
Printer Features
Media Handling
Cortex-A9 1.2 GHz
RAM
RAM Installed (Max)
1 GB / 3 GB (max)
Card Reader
Card reader
Supported Flash Memory Cards
SD Memory Card, SDHC Memory Card
Media Handling
Media Type
Plain paper
Media Size Class
A4/Legal
Max Media Size
Legal (216 x 356 mm), A4 (210 x 297 mm)
Min Media Size (Custom)
70 mm x 148 mm
Max Media Size (Custom)
216 mm x 356 mm
Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), Folio (216 x 330 mm), B6 (125 x 176 mm)
Media Weight
60 g/m² - 220 g/m²
600 sheets
Media Feeders
1 x automatic - 100 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 220 g/m² , 1 x automatic - 500 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 163 g/m²
Max Media Capacity
2100 sheets
Output Trays Capacity
500 sheets
Print server
Remote Management Protocol
SNMP 3
Security Protocols & Features
SSL, IPsec
Expansion Slots
1 x expansion slot
1 x USB 2.0 - 4 pin USB Type B , 2 x USB host - 4 pin USB Type A , 1 x Gigabit LAN - RJ-45
Consumables Included
1 x toner cartridge (black) - up to 8000 pages , 1 x toner cartridge (cyan) - up to 6000 pages , 1 x toner cartridge (magenta) - up to 6000 pages , 1 x toner cartridge (yellow) - up to 6000 pages
TUV, ISO 9001, GS, ISO 14001, ISO 7779, ISO 9296
Power supply - internal
Frequency Required
50/60 Hz
641 Watt
Power Consumption Stand by
77 Watt
Power Consumption Sleep
0.6 Watt
Sound Emission (Idle)
30 dBA
Sound Emission (Operating)
53.5 dBA
39 cm
53.2 cm
46.95 cm
31 kg
Accessories
