With interfaces for Gigabit Ethernet, USB 2.0, and USB host, alongside wireless capabilities including Apple AirPrint, Kyocera Mobile Print, and more, this printer ensures seamless integration into any office environment.
High-quality printing
Leveraging laser technology, the Kyocera ECOSYS MA4500ix delivers monochrome printing with a maximum resolution of 1200 x 1200 dpi, ensuring crisp and clear documents every time.
Robust security features
Equipped with advanced security protocols including IPsec, LDAP, SMTP, SNMP 3, and TLS, this printer safeguards sensitive information, making it a reliable choice for businesses.
Versatile media handling
Supports a wide range of media sizes from A6 to Legal and weights from 60 g/m2 to 220 g/m2, coupled with a total media capacity of 600 sheets, this printer is designed to handle diverse printing needs.
Eco-friendly design
Adhering to environmental standards such as ISO 14001 and TUV, the Kyocera ECOSYS MA4500ix is designed with sustainability in mind, reducing the ecological footprint of your office operations.
Kyocera ECOSYS MA4500ix - printer - B/W - laser
Printer Type
Workgroup printer - laser - B/W
22.5 kg
Media Size Class
A4/Legal
Max Media Size
Legal (216 x 356 mm), A4 (210 x 297 mm)
Min Media Size (Custom)
70 mm x 140 mm
Max Media Size (Custom)
216 mm x 356 mm
Print Speed
Up to 45 ppm - B/W - A4 (210 x 297 mm) , Up to 22.5 ppm - B/W duplex - A4 (210 x 297 mm)
100-sheet multipurpose tray, 500-sheet paper cassette
Recommended Monthly Volume
20000 pages
Print server
Printer Features
23 sec warm-up time, WSD print, E-mail printing, PDF direct print, Internet printing, secure printing IPP over TLS, local and network authentication, secure boot, trusted platform module, run time integrity check
AC 220-240 V
Apple MacOS X 10.9 or later, Google Chrome OS, Linux
1-year warranty
47.5 cm x 47.6 cm x 57.5 cm
Printer Type
Workgroup printer - laser - monochrome
Printer
Print Speed
93 x outline , 4 x calibri , 4 x cambria , 1 x bitmapped , 45 x barcode
Printer Features
Media Handling
ARM A53 1.4 GHz
RAM
RAM Installed (Max)
1.5 GB / 3.5 GB (max)
Card Reader
Card reader
Supported Flash Memory Cards
SD Memory Card, SDHC Memory Card
Media Handling
Media Type
Plain paper
Media Size Class
A4/Legal
Max Media Size
70 mm x 140 mm
216 mm x 356 mm
Media Sizes
A4 (210 x 297 mm), A5 (148 x 210 mm), A6 (105 x 148 mm), B5 (176 x 250 mm), B6 (125 x 176 mm), ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Folio (216 x 330 mm)
Media Weight
60 g/m² - 220 g/m²
Total Media Capacity
600 sheets
Media Feeders
Multi-purpose tray: 1 x automatic - 100 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 220 g/m² , Paper cassette: 1 x automatic - 500 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 220 g/m²
Max Media Capacity
2600 sheets
Output Trays Capacity
500 sheets
Duty Cycle
20000 pages
Print server
Security Protocols & Features
IPsec, LDAP, SNMP 3, SMTP, TLS
Expansion Slots
1 x expansion slot
1 x USB 2.0 , 1 x USB host , 1 x Gigabit LAN - RJ-45
Consumables Included
1 x toner cartridge (black) - up to 6000 pages ISO/IEC 19752 - Kyocera TK-3300 Starter
ISO 7779, ISO 9296, TUV, GS, ISO 9001, ISO 14001
Power supply
AC 220-240 V
Frequency Required
50/60 Hz
599.4 watt
Power Consumption Sleep
0.5 watt
Limited warranty - 1 year
Sound Emission (Idle)
30 dBA
Sound Emission (Operating)
54 dBA
47.5 cm
47.6 cm
57.5 cm
22.5 kg
Width (Shipping)
60.7 cm
Depth (Shipping)
57 cm
Height (Shipping)
69.5 cm
Weight (Shipping)
30 kg
