With a maximum copying speed of 40 pages per minute and a first copy out time of just 6.4 seconds, the MA4000wifx is built to handle high-volume printing efficiently. The robust monthly duty cycle allows for extensive use without interruptions.
Flexible connectivity
Equipped with USB 2.0, Gigabit LAN, and Wi-Fi connectivity, this printer ensures easy integration into office networks. The ability to connect seamlessly enhances productivity and makes it suitable for various workplace setups.
Enhanced document security
This printer includes multiple advanced security features such as TLS 1.3 encryption, IP filtering, and LDAP support. These protocols help protect sensitive information, making it suitable for businesses that prioritize confidentiality.
Versatile mobile printing
Supports several mobile printing solutions including Apple AirPrint, Mopria Print Service, and Kyocera Mobile Print. This feature enables users to print directly from their devices, enhancing convenience and flexibility in daily operations.
Intuitive user interface
Featuring a 4.3-inch LCD touch screen, the user interface offers easy navigation through the printer’s functions. This design simplifies operation for users, making it accessible for everyone in the workplace.
Save to USB flash drive, Network fax server, scan to e-mail, scan to network, Private print, scan to FTP, scan to SMB, IPP printing, scan to USB host, embedded OCR, Proof and Hold, Quick Copy, Job Storage
AC 220-240 V (50/60Hz)
41.7 cm x 41.2 cm x 43.7 cm
19.5 kg
Environmental Standards
EPEAT Gold
3-year warranty
Printer Fonts
Outline , Bitmapped x 1 , Calibri x 4 , Cambria x 4 , Barcode x 45
Multifunction printer
Printing Technology
Laser - monochrome
Monthly Duty Cycle (max)
80000 pages
Recommended Monthly Volume
2000 pages
Display Diagonal Size
4.3"
Display Colour Support
Display Features
Touch screen, LCD display
Connection Availability
USB 2.0, Gigabit LAN, USB host, Wi-Fi(ac)
AirPrint Enabled
Office Machine Features
Standard Memory
2 GB
Supported Flash Memory
SD Memory Card, SDHC Memory Card
Copying
Max Copying Speed
Up to 40 ppm
Max Copying Resolution
Up to 600 x 600 dpi
Grayscale Half-Tones
256
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
999
Exposure Control
Automatic, manual
Exposure Modes
Text, photo, text and photo, map, printed document
Automatic Duplexing
Copying Features
Toner Save, 2 on 1, auto colour select, 4 on 1, ID Card Copy, Multiple Copy, blank page skipping, Borderless copy, watermark, electronic sorting, Split Scan, economy mode, adjustable copy density, Base Colour Removal, auto crop to content
Printing
Max Printing Resolution
Up to 1200 x 1200 dpi
Max Printing Speed
Up to 40 ppm
Printer Drivers / Emulations
PCL 5e, PostScript 3, IBM Proprinter, KPDL3, PCL 6 (XL), PDF 1.7, TIFF, XPS, EPSON LQ-850, JPEG, PRESCRIBE
Automatic Duplexing
First Print Out Time B/W
6.4 sec
Scanning
Automatic Duplexing
Optical Resolution
600 x 600 dpi
Fax Machine
Compatibility
Super G3
Max Transmission Speed
33.6 Kbps
Data Compression System
MH, MR, MMR, JBIG
Fax Resolutions
200 x 400 dpi, 200 x 200 dpi, 200 x 100 dpi, 400 x 400 dpi
Reception Memory Capacity
Up to 256 pages
Fax Machine Features
Remote Fax Retrieval (Polling)
Fax forwarding, Duplex Fax, direct fax
Document & Media Handling
Min Original Size
A6 (105 x 148 mm)
Max Original Size
Legal (216 x 356 mm)/A4 (210 x 297 mm)
Supported Original Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm)
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), Statement (139.7 x 215.9 mm), B6 (125 x 176 mm), 70 x 148 mm, Oficio (215 x 335 mm)
Supported Envelope Sizes
International DL (110 x 220 mm), International C5 (162 x 229 mm), Monarch (98.4 x 190.5 mm)
Standard Media Capacity
350 sheets
Max Media Capacity
850 sheets
Bypass Feeder Capacity
50 sheets
Output Trays Capacity
150 sheets
Multi-purpose tray - 100 sheets size: 70 x 148 mm - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 60 g/m² - 220 g/m² , Paper cassette - 250 sheets size: A6 (105 x 148 mm) - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 60 g/m² - 163 g/m² , ADF - 50 sheets size: A6 (105 x 148 mm) - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 50 g/m² - 160 g/m² , Output tray - 150 sheets size: 70 x 148 mm - Legal (216 x 356 mm)/A4 (210 x 297 mm)
Speed Details
Printing: up to 40 ppm (A4) - B/W , Printing: up to 20 ppm (A4) - B/W duplex , Scanning: up to 40 ipm (A4) - B/W (300 dpi) , Scanning: up to 23 ipm (A4) - colour (300 dpi) , Scanning: up to 80 ipm (A4) - B/W duplex (300 dpi) , Scanning: up to 46 ipm (A4) - colour duplex (300 dpi)
1 x USB 2.0 - 4 pin USB Type B , 1 x USB host - 4 pin USB Type A , 1 x Gigabit LAN - RJ-45
Security Protocols & Features
Kerberos, LDAP, TLS, IPsec, IP filtering, port blocking, TLS 1.3 Encryption, active directory, NTLM v2
Operating System Support
MS Windows, Chrome OS, Apple Mac OS X 10.9 or later
574.4 watt
Power Consumption Standby
11 watt
Power Consumption Sleep
0.4 watt
Warm-Up Time
29 sec
First Copy Out Time B/W
6.4 sec
Consumables Included
1 x toner cartridge (black) - up to 3600 pages ISO/IEC 19752 - Kyocera TK-1270 Starter
ISO 9001, ISO 14001, ISO 7779, ISO 9296, TUV-GS
EPEAT Compliant
EPEAT Gold
Limited warranty - 1 year , Limited hardware warranty - drum - 3 years / 100000 pages
41.7 cm
41.2 cm
43.7 cm
19.5 kg
Shipping Width
55.5 cm
Shipping Depth
54.1 cm
Shipping Height
57.2 cm
Shipping Weight
24 kg
Sound Emission
29 dBA (idle) / 52 dBA (operating)
10 °C
32.5 °C
10 - 80% RH
