The ECOSYS M5521cdn A4 professional all-rounder meets any business requirements. The scan, copy, fax and mobile scan functions ensure an optimized and flexible workflow. Mobile printing support takes this to the next level and, compatible with both mobile devices, offers every office the modern standards in technology. Additionally, the app offers you an easy way to operate this multifunctional printer from your smartphone. A powerful device, that fits perfectly into businesses, where a wide variety of functions are required.
Up to 21 pages per minute in A4 in colour and black and white
1,200 dpi printing quality
Mobile printing support including AirPrint, Mopria, KYOCERA Mobile Print
Double-sided print, copy, scan and fax functionality as standard
Direct printing from and scanning to USB flash memory
With interfaces for Gigabit Ethernet, USB 2.0, and USB host, this device ensures seamless integration into any office network, facilitating easy sharing and management of documents.
Versatile media handling
Accommodates a wide range of media sizes from A6 to Legal, and weights from 60 to 220 g/m2, making it suitable for various document types, from lightweight papers to thick cardstocks.
High-quality copying
Features like 2 on 1, 4 on 1, Auto Color Mode, and ID Card Copy, combined with a maximum copying resolution of 600 x 600 DPI for both color and B/W, ensure crisp, clear copies every time.
Advanced scanning capabilities
Offers fast scanning speeds up to 30 ipm in B/W and 23 ipm in color, with an optical resolution of 600 x 600 DPI, enabling efficient digitization of documents.
Eco-friendly operation
ENERGY STAR certified with a low power consumption in sleep mode of just 1 W, this device supports your office's green initiatives while minimizing energy costs.
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), B6 (125 x 176 mm), 70 x 148 mm
Standard Media Capacity
300 sheets
Max Media Capacity
550 sheets
Bypass Feeder Capacity
50 sheets
Output Trays Capacity
150 sheets
Input tray - 250 sheets size: A6 (105 x 148 mm) - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 60 g/m² - 163 g/m² , Bypass tray - 50 sheets size: 70 x 148 mm - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 60 g/m² - 220 g/m² , ADF - 50 sheets size: A6 (105 x 148 mm) - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 50 g/m² - 160 g/m² , Output tray - 150 sheets
Speed Details
Printing: up to 21 ppm (A4) - colour , Printing: up to 21 ppm (A4) - B/W , Copying: up to 21 ppm (A4) - B/W , Copying: up to 21 ppm (A4) - colour , Scanning: up to 30 ipm (A4) - B/W , Scanning: up to 23 ipm (A4) - colour
1 x USB 2.0 - 4 pin USB Type B ¦ 1 x USB host - 4 pin USB Type A ¦ 1 x Gigabit LAN - RJ-45
Operating System Support
UNIX, Linux, MS Windows, Apple Mac OS X 10.8 or later
AC 230 V (50Hz)
345 watt
Power Consumption Standby
41 watt
Power Consumption Sleep
1 watt
Warm-Up Time
32 sec
First Copy Out Time B/W
10 sec
First Copy Out Time Colour
12 sec
Consumables Included
1 x toner cartridge (cyan) - up to 1200 pages , 1 x toner cartridge (magenta) - up to 1200 pages , 1 x toner cartridge (yellow) - up to 1200 pages , 1 x toner cartridge (black) - up to 1200 pages
ISO 9001, ISO 14001, AS/NZS 3260, ISO 7779, ISO 9296
