Quicklinx: | DKCPWS00 |
Mfr#: | 1015114 |
The Kodak-Alaris S2000 A4 scanners are built to let anyone capture information anywhere, with superior image quality and data accuracy. It’s the perfect solution when you need to get information into your business fast.
Embedded Image Processing delivers crisp, high-quality images without depending on your PC.
Active Feed technology perfectly aligns pages to avoid misfeeds and multifeeds.
Perfect Page optimizes image quality on every page for accurate information extraction.
Can be paired with the excellent Alaris Passport Flatbed Accessory, for simple and high-quality scans of legal-size documents including passports.
The S2060W scans at speeds of up to 60 pages per minute, whilst the S2080w scans at speeds of up to 80 pages per minute. Crucially, these scanners are wifi and network compatible, to allow for even greater efficiency and access for you and your staff in the office. The scanners have a 3.5" colour display, where jobs can be customised and selected quickly, meaning that a scanned document can be shared to a selected destination within seconds.
In addition, the range can be purchased with Alaris Simple Invoicing Software suite, allowing for effective invoice procesing for your small business.
Contact Us for pricing and installation.
Kodak Alaris Perfect Page Software
Perfect Page is an Image Enhancement Software tool, produced by Kodak-Alaris. It is bundled as standard, with all Kodak-Alaris scanners, and is designed to improve visibility of scanned media. This, in turn, will save your business time during the scanning process, but also when retrieving digital documents. Perfect Page features advanced image enhancement features, such as:
De-skew and auto-cropping
Auto-Orientation
Auto-Brightness
Sharpening
Intelligent Background Colour Smoothing
Streak Removal
Noise Reduction
The Kodak Alaris S2060W scanner can be tethered to the Kodak Alaris A3 Flatbed Scanner accessory for A3 scanning of fragile documents, large-scale drawing plans, photographs, artwork etc.
