Wait less, do more
The perfect companion for the avid photographer, videographer, design studios or printing houses, the USB 3.0 Media Reader is compatible with all major media cards types. As card capacities and file sizes increase, there is an increasing need to get your images transferred faster.
Rely on Kingston's USB 3.0 Media Reader to quickly move data between multiple devices. Use it at home or on the road; its convenient size makes it ultra-portable.
USB 3.0 offers the same ease of use and plug-and-play capabilities as previous generations of USB technologies but with a performance increase (up to 10 times faster than USB 2.0) and better power management. This USB 3.0 Media Reader is backwards compatible with USB 2.0.
The USB 3.0 Media Reader is backed by a two-year warranty and legendary KingstonĀ® reliability.
- USB 3.0 -- up to 5.0Gb/s data transfer speed
- Ultra portable; sleek metal construction
- Maximise the full speed potential of your memory cards
FEATURES
- Built-in LED indicator and three-foot USB 3.0 cable
- Portable -- convenient small size
- Versatile -- works with the following Flash card formats:
CompactFlash (CF Type I (UDMA 0-6) , CF Type II (UDMA 0-6) )
Secure Digital ( SD , SDHC , SDHC UHS-I , SDXC , SDXC UHS-I )
microSD ( microSD , microSDHC , microSDXC , Memory Stick/M2 , Memory Stick , Memory Stick PRO , Memory Stick Duo , Memory Stick PRO Duo , Memory Stick M2 )
- Requirements -- system with USB 3.0 port
- Backwards compatible -- with USB 2.0
