Back
Generic Memory
Kingston 8GB DDR4-2400MHz Reg ECC Memory
Quicklinx:
DQQ1WS00
Mfr#:
KTD-PE424S8/8G
Back
Kingston DDR4 8 GB DIMM 288-pin 2400 MHz / PC4-19200 CL17 1.2 V registered ECC
Kingston - DDR4 - module - 8 GB - DIMM 288-pin - 2400 MHz / PC4-19200 - registered
Memory module
8 GB
Memory Type
DDR4 SDRAM - DIMM 288-pin
Upgrade Type
System specific
Data Integrity Check
ECC
Speed
2400 MHz (PC4-19200)
Latency Timings
CL17
Registered
Voltage
1.2 V
Lead Plating
Gold
DELL A8711886
Limited lifetime warranty (Russia - 10 years)
Dell PowerEdge C4130, C6320, FC430, FC630, FC830, M630, M830, T430, T630; Precision Rack 7910; Precision Tower 3420, 3620, 5810, 7810, 7910
8 GB
Upgrade Type
System specific
DELL A8711886
DRAM memory module
DDR4 SDRAM
DIMM 288-pin
Speed
Latency Timings
CL17
ECC
Registered
Module Configuration
1024 X 72
Voltage
1.2 V
Lead Plating
Gold
Dell PowerEdge C4130, C6320, FC430, FC630, FC830, M630, M830, T430, T630 , Dell Precision Rack 7910 , Dell Precision Tower 3420, 3620, 5810, 7810, 7910
